Wifi issue
Wifi issue
Hi Folks:
I have found today my wifi attachment blinking blue and without connection at all.
Perhaps my modem just rejected the connection but what I did with out success was:
- Restore to factory settings (blue light and green still blinking)
- Update Firmware with no success either:
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM7
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM7
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM7
< CMD
> factory RESET
< factory RESET
< Set Factory Defaults
> reboot
< <2.32>
< reboot
Factory Settings Restored
< CMD
> set u b 57600
< set u b 57600
< AOK
< <2.32>
> set s p 0
> save
< <2.32>
> reboot
< CMD
> reboot
< reboot
< CMD
> ftp u
< ftp u
< <2.32>
< FTP connecting to 208.109.78.34
< FTP timeout=2
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
> ftp u
Updating firmware requires the Reef Angel Wifi Attachment to be connected to your wifi network and be able to access the internet.
If you have the blue LED blinking, it means that your Reef Angel Wifi Attachment is still not connected to your wifi network.
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ftp u
< ftp u
< <2.32>
Also I tried to install by Arduino, sketchbook, wifitest and it does time out with out success..
help please
thank you heaps in advance.
Erick
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
> reboot
< <2.32>
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <2.32>
> set s p 0
> save
< <2.32>
> reboot
< CMD
> reboot
< reboot
< CMD
> ftp u
< ftp u
< <2.32>
< FTP timeout=2
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
> ftp u
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ftp u
< ftp u
< <2.32>
help please
Erick
Re: Wifi issue
The manufacturer changed servers and that's why the wifi utility is failing to download the updated firmware.
I need to update that utility.
Can you use Dave's for now?
https://github.com/davemolton/Graphical ... ves/master
Re: Wifi issue
I tried to run Dave's wifi tool but it gave me a .net error. I'm not familiar with windows anymore. What should I do?
Re: Wifi issue
It does run 4.0
I'll try again after just 65 windows xp updates will be installed on my old laptop.
Re: Wifi issue
k, I'm running Dave's utility. How to update the firmware?
Got it but doesn't work:
CMD
ftp u
<2.32> FTP connecting to 208.109.78.34
FTP timeout=3
ftp u
FTP timeout=3
CMD
ftp u
FTP timeout=3
ftp u
FTP timeout=3
Re: Wifi issue
Yes, the manufacturer keeps changing the ip address.
The latest one is 198.175.253.161
So, you need to send:
set f a 198.175.253.161
Re: Wifi issue
<2.32> FTP connecting to 198.175.253.161
FTP file=65
FTP OK.
UPDATE OK
ver
WiFly Ver 2.36, 08-25-2012 on RN-131
<2.36>
What should I do now?
I did:
- factory RESET
- reboot
Dave's utility connect at 9600
- apply basic settings
Dave's utility connect 57600
- apply my wifi settings
- apply reefangel.com config
Now, my router's utility identifies it as WiFly-GSX not as reefAngel WiFI
Does it matter? How do I change the module's wifi's name?
FTP file=65
FTP OK.
UPDATE OK
ver
<2.36>
I did:
- factory RESET
- reboot
Re: Wifi issue
Since I updated the fw and installed the WiFi antenna, the reception and connection improved. But, once in a while, I'm can't access the controller from my iphone or pc but this time the module is blinking green not blue as before. To fix this issue, I have to unplug the wifi module for 1 sec. How to fix it for good?
Re: Wifi issue
This is what the manufacturer asked us to try:
http://forum.reefangel.com/viewtopic.php?p=10947#p10947
Re: Wifi issue
I'm using the 2nd set of instruction, I hope it helps.
set sys sleep 86400
set sys wake 1
save
reboot
set sys sleep 86400
set sys wake 1
save
reboot
Re: Wifi issue
I don't know if it's coincidence or not, after dloading the latest RA libraries I'm experiencing huge wifi issues. I have to disconnect the wifi adapter every few minutes ir order to make it work. Any idea what could be the problem?
