Memory section of iPhone app
This may be an ignorant question but how does the memory section work? When I go to that section of the app it has different parameters than I have programmed into the RA. Does it change the code I have written? Is it a temporary change or permanent?
Re: Memory section of iPhone app
The memory section allows you to update the values that are used. They only come into play when you use the internal memory functions. If you have hard coded values then the memory section is not applicable.
If the code was created automatically by the wizard is this hard code? Because I'm thinking maybe that's the reason why the functions in the memory won't work.
How do I switch from using hard code to internal memory without redoing all the code?
Technically it is just removing the parameters and leaving just the port number.
Can you post your code?
Just an fyi...when i try an change memory locations on my iPhone the app crashes..so test that first otherwise you maybe investing time in something that is broken..
which libraries are you running? It was built for the pre 1.0 versions, the locations are different on the newer libraries. Working on an update now.lnevo wrote:Just an fyi...when i try an change memory locations on my iPhone the app crashes..so test that first otherwise you maybe investing time in something that is broken..
Now i am on 1.2. Crashes were with using the custom locations. Glad to hear some work being done! We are lagging behind the android appwolfador wrote:which libraries are you running? It was built for the pre 1.0 versions, the locations are different on the newer libraries. Working on an update now.lnevo wrote:Just an fyi...when i try an change memory locations on my iPhone the app crashes..so test that first otherwise you maybe investing time in something that is broken..
whoa. he's baaack.wolfador wrote:which libraries are you running? It was built for the pre 1.0 versions, the locations are different on the newer libraries. Working on an update now.lnevo wrote:Just an fyi...when i try an change memory locations on my iPhone the app crashes..so test that first otherwise you maybe investing time in something that is broken..
