Hi All
Unfortunately our distributors in South Africa have decided not to import RA+ Units.
My concern now is will I have enough memory?
This may be a very open ended question but how much will this limit me in terms of what I can do with the system?
I won't need to control lighting besides on/off, but am keen to run wifi, vortech's and then the standard ph, ATO, temp etc.
Any help would be great thanks
Memory Issues
Re: Memory Issues
Lockes,
All you have to do is keep the code to what you need and you'll be fine. So far on mine I run Vortechs via the RD module, ATO, Salinity, PH, 3 x temp probes, I have 2 x switch boxes and the wifi unit.. etc .. It CAN be done with the standard unit!
btw I'm also in South Africa. The guys at Drop Reef can get the RA+ unit if you really want one.
Justin
Justin
Re: Memory Issues
I think you should be fine with the standard RA, but if you are concerned, you can order a RA+ from Drop Reef in South Africa if you can wait a couple weeks. This is how long it usually takes for packages to get to them.
I'll let them know of your interest.
- JNieuwenhuizen
Re: Memory Issues
Hi Lockes
We will be shipping in RA+ units with the next shipment.
As Roberto and Ishtak stated, for whatyou are mentioning, the RA will be fine.
Regards
Jean - Drop Reef
Regards
Jean - Drop Reef
