Driver installation issue
Seagals
Post by Seagals »
I am trying to set up my new RA+ and started by downloading the software for computer, unfortunetly i keep getting the following error code:
"No ports were found, please check if your cable is properly pugged in and click the Back button twice to repeat the driver installation process"
I have tried this several times in different ports, no luck. I rebooted the compuer, no change, I also uninstalled and reinstalled software....no luck.
When i go my control panel on the computer in does recognize when I have the usb cable plugged/unplugged.
Also, searched the forums, no luck
I am running Windows - any advise?
Re: Driver installation issue
Try installing the latest drivers from the manufacturer's website.
http://www.ftdichip.com/Drivers/VCP.htm
As of now, the latest version is this:
http://www.ftdichip.com/Drivers/CDM/CDM20824_Setup.exe
