the time on my controller is off but every time I go into the setup menu it resets me back to the main screen. I can't access any level 3 / 4 menu without it resetting. Is there a fix for this? Thanks.
Jeremiah
BUG - I can't set my time or enter sub menus
aranax
Re: BUG - I can't set my time or enter sub menus
The next update of libraries that Curt is working on will fix this problem.
Hopefully we can see it soon
aranax
Awesome. Thanks Roberto. BTW...did you get the parts back? I've been out on paternity leave and sent them through my works mailroom. They are NOTORIOUS for sitting on things until they get yelled at. Let me know. Thanks.
Jeremiah
Jeremiah
- Contact:
what version are you running now?aranax wrote:the time on my controller is off but every time I go into the setup menu it resets me back to the main screen. I can't access any level 3 / 4 menu without it resetting. Is there a fix for this? Thanks.
Jeremiah
also what do you mean by level 3 / 4 menu? do you mean like going to setup then standard lights or something similar?
He's got early release of optiboot. I think v1.0
The reset is due to wdt kicking in that I mentioned to you when using the menu system when it does not come back to loop() for wdt_reset().
- Contact:
OH....ok. I'm following you now. I was confused at first but now it makes a little more sense.rimai wrote:He's got early release of optiboot. I think v1.0
Curt has released the new libraries, which includes a fix for this issue.
What needs to be done is inside the ReefAngel_Features.h file, you need to uncomment or add a line:
This is only to be used by users with optiboot.
For optiboot v4.0
For optiboot v2.1 or lower
I know that your bootloader is version 2.1 or lower, so use the second.
For optiboot v4.0
#define WDT
#define WDT_FORCE
aranax
