BUG - I can't set my time or enter sub menus
Posted: Fri Jul 15, 2011 9:33 pm
by aranax
the time on my controller is off but every time I go into the setup menu it resets me back to the main screen. I can't access any level 3 / 4 menu without it resetting. Is there a fix for this? Thanks.
Jeremiah
Re: BUG - I can't set my time or enter sub menus
Posted: Fri Jul 15, 2011 9:36 pm
The next update of libraries that Curt is working on will fix this problem.
Hopefully we can see it soon
Posted: Fri Jul 15, 2011 9:39 pm
by aranax
Awesome. Thanks Roberto. BTW...did you get the parts back? I've been out on paternity leave and sent them through my works mailroom. They are NOTORIOUS for sitting on things until they get yelled at. Let me know. Thanks.
Jeremiah
Posted: Sat Jul 16, 2011 5:40 am
by binder
aranax wrote:the time on my controller is off but every time I go into the setup menu it resets me back to the main screen. I can't access any level 3 / 4 menu without it resetting. Is there a fix for this? Thanks.
Jeremiah
what version are you running now?
also what do you mean by level 3 / 4 menu? do you mean like going to setup then standard lights or something similar?
Posted: Sat Jul 16, 2011 9:27 am
He's got early release of optiboot. I think v1.0
The reset is due to wdt kicking in that I mentioned to you when using the menu system when it does not come back to loop() for wdt_reset().
Posted: Sat Jul 16, 2011 10:23 am
by binder
rimai wrote:He's got early release of optiboot. I think v1.0
OH....ok. I'm following you now. I was confused at first but now it makes a little more sense.
Posted: Thu Jul 21, 2011 9:27 pm
Curt has released the new libraries, which includes a fix for this issue.
What needs to be done is inside the ReefAngel_Features.h file, you need to uncomment or add a line:
This is only to be used by users with optiboot.
For optiboot v4.0
For optiboot v2.1 or lower
I know that your bootloader is version 2.1 or lower, so use the second.
Posted: Sat Jul 23, 2011 10:34 am
by aranax
thanks Robert. Works perfectly.
Jeremiah
