Hello All,
I wanted to see if there is a way to controll the dimming of the leds from your phone app?
Also when I loaded the wifi code to connect I do not have a lights option in the controller. is that normal? is there a way to ramp the lights from the controller or the phone?
Any help with be greatly appricated.
Allen
Dimming light control from your phone
Re: Dimming light control from your phone
If you want to add the lights menu, you need to add this to your code:
Did you use the Reef Angl Wizard to generate your code?
ReefAngel.AddStandardMenu();
no the only thing I have added is the wireless test code and then I started haveing issues with that. I need to get that resolved first and then worry about the lights,
