client suite service dash crash
grafxalien
Post by grafxalien »
Hello- Just recently bought a new laptop with windows 7. I installed the client suite fresh on it and everything was working fine until yesterday. The wifi address of the reefangel changed so it is no longer connecting to client suite. Every time i try to run the service dash to change the IP address it instantly crashed. I have tried to uninstall/reinstall and that did not fix the problem. any ideas?
Re: client suite service dash crash
You may need to send a pm to Dave (dmolton)... I've never seen this problem.
Ademster
Post by Ademster »
I had this problem at first aswell..
I changed it when connected to the cable, hit save.. then I removed the cable hooked up the wifi again and it worked.
Adam
58 Gal
