New Wifi Utility instructions?
knapp870
Post by knapp870 »
Hey everyone, so I set up my wifi module again due to it stopped working after i moved my tank and was flashing blue. I tried using the new wifi utility, but could not find updated instructions? Also, when using the new utility, do you enter local port as 2000? The module is now slowly flashing green, my router shows it has an IP, but it is not reporting to the port and I am unable to connect to it via phone. Thoughts? The one thing I was wondering is I did not enter anything into local port when using the new utility. Thanks!!
Re: New Wifi Utility instructions?
New utility will always use 2000 by default.
Maybe you need to look at your port forwarding settings inside your router?
knapp870
Post by knapp870 »
I checked those, they appear to be unchanged from what they were when it was working. Other ideas? Could there be something wrong with the wifi attachment?
Can you ping the ip address assigned to the wifi attachment?
Did you load any new code to the controller.
I recommend you testing it with the WifiTestCode.
File->Sketchbook->Example Codes->WifiTestCode
Can you browse http://ipaddress:2000 ?
alexwbush
Post by alexwbush »
which graphical utility did you use?
I just setup wifi yesterday using http://forum.reefangel.com/viewtopic.php?f=15&t=345 and it went smoothly never asking me to specify a port.
