problem with pH reading
After about a month of working correctly, yesterday the pH reading dropped to ~2 and then raised to ~5. I recalibrated the probe. The reading for pH7 and pH10 went down respectively from 554 to 457 and from 832 to 741. When I put the probe back to the tank or sump it still reads ~5. When I test this probe in a cup with the water from the tank it shows 8.11 which is about right. So i thought voltage leaking in the tank. I tried to unplug every item one by one with no results, the reading remained in the ~5 range. Tested it in cup again and it shows over 8 which is correct. What could be the reason of the false reading when the prob is in the tank/sump? Also keep in mind that it just happened yesterday.
Re: problem with pH reading
That was it, when ATO switch is unplugged pH reading goes back to normal.
Is there a way to fix this bad switch or I need to order a new one?
Was it the exposed leads that was touching the water or the float itself that causes the issue?
The leads are outside the sump and I isolated them with electrical tape, it must be the floating part of the switch.
