changing wavemaker time on controller makes ato turn on?
Posted: Sun Sep 16, 2012 2:02 pm
Hey Roberto I was wondering if you could help me... i uploaded 1.0.1 to controller... when i change wavemaker time in controller it made my ato pump turn on? this is the code. The only thing that i added was the line that makes wavemaker pumps work opposite of each other. did i put it in wrong spot? thanks for your help
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.SingleATOLow( Port1 );
ReefAngel.MoonLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.ActinicLights( Port4 );
ReefAngel.Wavemaker1( Port5 );
ReefAngel.Wavemaker1( Port6 );
