what is this cable for
Posted: Mon Sep 17, 2012 10:23 am
Not sure what this cable is for.
Can some one tell me
Thanks for the help
Thanks for the help
https://forum.reefangel.com/
Welcome to the club, I have destroyed nearly half the plastic connectors on my RA trying to remove them. Now I keep a pair of needle nosed pliers with my controller at all times. Grab the plastic and pull.kahlif wrote:So, used that cable today for the first time to setup my new RA. I plugged it and it worked great. However, when I went to unplug it, the wires pulled right out of the plug in the RA.
Because of how recessed the connector is inside the housing, I could not get a good grip on the plug, and I guess I pulled on the cable a bit.
Any ideas?
It's called a "USB Power Cable". It is in the Store available for purchase.bigHUN wrote:and what is that cable called again? actually where did you got it?
I just got the plus controller board (only) and will be replacing the old board
this I may be utilizes somewhere else in the house
