argh error!
reefcycle
argh error!
Post by reefcycle »
so frustrated every time I try to code I get color errors or port not specified but I did the reef angel wizard verbatim. I get so frustrated with this! argh!
// Autogenerated file by RAGen (v1.2.2.171), (10/07/2012 13:43)
// RA_100712_1343.pde
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define RelayExp
#define InstalledRelayExpansionModules 0
#define WDT
#define SIMPLE_MENU
#define RFEXPANSION
#define IOEXPANSION
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_RF.h>
    ReefAngel.FeedingModePorts = B00000000;
    ReefAngel.WaterChangePorts = B11000101;
    ReefAngel.OverheatShutoffPorts = B00001100;
    ReefAngel.StandardLights(Port1);
    ReefAngel.MHLights(Port2);
    ReefAngel.StandardFan(Port4);
    ReefAngel.DosingPump1(Port7);
    ReefAngel.DosingPump2(Port8);
    ReefAngel.Portal("reefcycle", "*******");
I just want port 1 standard port 2 mh port 3 heater port 4 mh port 5 and port 6 not dedicated port 7 dosing pump 1 port 8 dosing pump 2. I have rf expansion water level and i/o hub. I have wifi and thats already working. I just want it all to work. I can sucessfully upload preload code or initial settings but I am doing something simple wrong and it is causing chaos!
Re: argh error!
Seems you are using headers from old RAGen and code from Wizard.
The headers have changed, so the includes in your code are outdated.
Make sure you use the same headers that Wizard is outputting.
reefcycle
Re: argh error!
Post by reefcycle »
Where are those options?
Re: argh error!
There are no options. Just use the code from Wizard as is.
You don't need to copy and paste the code. Why are you copying and pasting code from wizard to an old code?
These libraries belong to a really old library set that is outdated and no longer works or is supported. You should not use it anymore.
reefcycle
Re: argh error!
Post by reefcycle »
I started from fresh since I was able to use my desktop since I purchased USB power cable. So I downloaded all new. I am so confused lol
Re: argh error!
The code you posted says this on top
That tells me that you generated this code from RAGen and not Wizard.
reefcycle
Re: argh error!
Post by reefcycle »
I don't know how. I am not denying it happened im just at a loss for how. Should I uninstall and try again
Re: argh error!
Can you go through the wizard again and choose "Generate Only" at the end.
Then paste the code here once again.
Just to be sure. You are using Wizard by using menu Tools->Reef Angel Wizard, right?
reefcycle
Re: argh error!
Post by reefcycle »
it has it on top again this is from wizard
// Autogenerated file by RAGen (v1.2.2.171), (10/07/2012 14:34)
// RA_100712_1434.pde
#define VersionMenu
#define wifi
#define RelayExp
#define WDT
#define SIMPLE_MENU
#define RFEXPANSION
#define IOEXPANSION
    ReefAngel.Portal("reefcycle", "zzxx4118");
Re: argh error!
rimai wrote: Just to be sure. You are using Wizard by using menu Tools->Reef Angel Wizard, right?
RAGen is not the same as Wizard.
I'm pretty sure you are using RAGen.
reefcycle
Re: argh error!
Post by reefcycle »
Wizard created it, and then it launches arduino
Re: argh error!
That's what I mean.
You are not using Wizard. You are using RAGen, which is deprecated.
http://forum.reefangel.com/viewtopic.php?f=8&t=1297
Open Arduino and go to menu Tools->Reef Angel Wizard
reefcycle
Re: argh error!
Post by reefcycle »
wow I didnt even know that was there I am an idiot
