argh error!
Posted: Sun Oct 07, 2012 10:46 am
so frustrated every time I try to code I get color errors or port not specified but I did the reef angel wizard verbatim. I get so frustrated with this! argh!
I just want port 1 standard port 2 mh port 3 heater port 4 mh port 5 and port 6 not dedicated port 7 dosing pump 1 port 8 dosing pump 2. I have rf expansion water level and i/o hub. I have wifi and thats already working. I just want it all to work. I can sucessfully upload preload code or initial settings but I am doing something simple wrong and it is causing chaos!
// Autogenerated file by RAGen (v1.2.2.171), (10/07/2012 13:43)
// RA_100712_1343.pde
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define RelayExp
#define InstalledRelayExpansionModules 0
#define WDT
#define SIMPLE_MENU
#define RFEXPANSION
#define IOEXPANSION
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_RF.h>
ReefAngel.FeedingModePorts = B00000000;
ReefAngel.WaterChangePorts = B11000101;
ReefAngel.OverheatShutoffPorts = B00001100;
ReefAngel.StandardLights(Port1);
ReefAngel.MHLights(Port2);
ReefAngel.StandardFan(Port4);
ReefAngel.DosingPump1(Port7);
ReefAngel.DosingPump2(Port8);
// This sends all the data to the portal
// Do not add any custom code that changes any relay status after this line
// The only code after this line should be the ShowInterface function
ReefAngel.Portal("reefcycle", "*******");
