Ah, spoke to soon. Initially it worked, but I changed the time and now when I load the ino file the screen turns white and both pumps stay on, along with my ato port (without being triggered by the float switch). If I comment out the code and upload it everything seems okay. Here's my ino with the autofeed commented out. When I loaded the autofeed code I did comment out the original wavemaker stuff so I don't think that's what caused the problem.
/* Features
#define SIMPLE_MENU
#define WATERLEVELEXPANSION
#define RelayExp
#define SaveRelaysPresent
#define ENABLE_EXCEED_FLAGS
#define CUSTOM_VARIABLES
#define CUSTOM_MAIN
#define wifi
#define SALINITYEXPANSION
#define DisplayLEDPWM
#define VersionMenu
#define WDT
#define Return Port4
#define CaDoser Box1_Port3
#define AlkDoser Box1_Port4
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit;
ReefAngel.WaterChangePortsE[0] = Port8Bit | Port7Bit | Port6Bit | Port5Bit ;
ReefAngel.OverheatShutoffPorts = Port3Bit;
// Temperature and overheat functions
ReefAngel.Relay.On( Port4 );
ReefAngel.CustomVar[7]=1;
ReefAngel.StandardLights( Port1,9,0,21,0 );
ReefAngel.SingleATO( true,Port2,360,0 );
ReefAngel.StandardHeater( Port3,781,785 );
// Turn Port5 on/off random cycles that lasts from 10 to 15 secs
ReefAngel.WavemakerRandom( Port5,10,15 );
ReefAngel.StandardLights( Port7,21,0,23,0 );
ReefAngel.StandardLights( Port8,21,0,9,0 );
// ReefAngel.DosingPumpRepeat( Box1_Port3,0,120,2 );
// ReefAngel.DosingPumpRepeat( Box1_Port4,5,120,3 );
// Turn Port6 on/off on opposite cycle as Port 5
/*AUTOFEED if the hour is 11a, minute is 55 and seconds is 0
if ( ((hour() == 11) && (minute() == 55) && (second() == 00) ) )
ReefAngel.FeedingModeStart();
if (ReefAngel.DisplayedMenu=FEEDING_MODE)
ReefAngel.Relay.On (Port5);
ReefAngel.Relay.On (Port6);
//Dose Ca
if ( ReefAngel.DisplayedMenu == DEFAULT_MENU ) //Ca Doser - Only works if Main screen is showing
/* && = and || = or
Hours between 12am and 5am
minute must be 0 (top of the hour)
seconds less than 2 (up to 2 seconds)
if ( ((hour() >= 0) && (hour() <= 6)) && (minute() == 0) && //dose time
(second() < 2) ) //dose duration
ReefAngel.Relay.On(CaDoser);
ReefAngel.Relay.Off(CaDoser);
//Dose Alk
if ( ReefAngel.DisplayedMenu == DEFAULT_MENU ) //Alk Doser - Only works if Main screen is showing
/* && = and || = or
Hours between 12:05am and 7:05am
seconds less than 3 (up to 3 seconds)
if ( ((hour() >= 0) && (hour() <= 7)) && (minute() == 5) && //dose time
(second() < 3) ) //dose duration
ReefAngel.Relay.On(AlkDoser);
ReefAngel.Relay.Off(AlkDoser);
//Power Outage
ReefAngel.CustomVar[0]=ReefAngel.Relay.IsRelayPresent(EXP1_RELAY);
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
ReefAngel.Relay.Off (Port1);
ReefAngel.Relay.Off (Port2);
ReefAngel.Relay.Off (Port3);
ReefAngel.Relay.Off (Port5);
ReefAngel.Relay.Off (Port6);
ReefAngel.Relay.Off (Port7);
ReefAngel.Relay.Off (Port8);
ReefAngel.Relay.Off (Daylight); //port 1
ReefAngel.Relay.Off (AutoTopOff); //port 2
ReefAngel.Relay.Off (Heater); //port 3
ReefAngel.Relay.Off (WavemakerL); //port 5
ReefAngel.Relay.Off (WavemakerR); //port 6
ReefAngel.Relay.Off (WavemakerR); //port 7
ReefAngel.Relay.Off (FugeLight); //port 8
if (!ReefAngel.HighATO.IsActive())
ReefAngel.Relay.Off( Box1_Port6 );
//ATO/HEATER PORTAL PORTAL ALERT
if ( InternalMemory.read(ATO_Single_Exceed_Flag) == 1 )
ReefAngel.CustomVar[1]=1;
ReefAngel.CustomVar[1]=0;
if ( InternalMemory.read(Overheat_Exceed_Flag) == 1 )
ReefAngel.CustomVar[2]=1;
ReefAngel.CustomVar[2]=0;
ReefAngel.Portal( "chase", "2600" );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,54, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,54, ReefAngel.Params.Salinity );
// Water Level
ReefAngel.LCD.DrawText( COLOR_OLIVEDRAB,DefaultBGColor,75,54, "WL:" );
ReefAngel.LCD.DrawText( COLOR_OLIVEDRAB,DefaultBGColor,94,54, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawOutletBox( 12, 76, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 98, TempRelay );
