Feeding Mode + Wavemakers On
Posted: Fri Oct 19, 2012 2:32 am
by chase
Currently I have my WM sent on random via the following code:
 ReefAngel.WavemakerRandom( Port5,10,15 );
ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5));
I would like to 'override' the toggling function while in feeding mode so the pellets get blown around the tank and not just dumped off in one corner. To accomplish this I thought I could put the wavemaker code inside a feeding mode loop with something like this
if ( ((hour() == 12) && (minute() == 05) && (second() == 00) ) )
        ReefAngel.FeedingModeStart();
        ReefAngel.Relay.On (Port5);
        ReefAngel.Relay.On (Port6);
The wavemakers still toggle while in feeding mode though, any thoughts?
Re: Feeding Mode + Wavemakers On
Posted: Fri Oct 19, 2012 7:56 am
Try this:
if (ReefAngel.DisplayedMenu=FEEDING_MODE)
Posted: Fri Oct 19, 2012 3:03 pm
by chase
Perfect, thanks Roberto!
Posted: Fri Oct 19, 2012 3:41 pm
by chase
Ah, spoke to soon. Initially it worked, but I changed the time and now when I load the ino file the screen turns white and both pumps stay on, along with my ato port (without being triggered by the float switch). If I comment out the code and upload it everything seems okay. Here's my ino with the autofeed commented out. When I loaded the autofeed code I did comment out the original wavemaker stuff so I don't think that's what caused the problem.
/* Features
#define SIMPLE_MENU
#define WATERLEVELEXPANSION
#define RelayExp
#define SaveRelaysPresent
#define ENABLE_EXCEED_FLAGS
#define CUSTOM_VARIABLES
#define CUSTOM_MAIN
#define wifi
#define SALINITYEXPANSION
#define DisplayLEDPWM
#define VersionMenu
#define WDT
    #define Return        Port4
    #define CaDoser       Box1_Port3
    #define AlkDoser      Box1_Port4
        ReefAngel.FeedingModePorts = Port4Bit;
        ReefAngel.WaterChangePorts = Port2Bit | Port3Bit;
        ReefAngel.WaterChangePortsE[0] = Port8Bit | Port7Bit | Port6Bit | Port5Bit ;
        ReefAngel.OverheatShutoffPorts = Port3Bit;
        // Temperature and overheat functions
        ReefAngel.Relay.On( Port4 );
         ReefAngel.CustomVar[7]=1;
        ReefAngel.StandardLights( Port1,9,0,21,0 );
        ReefAngel.SingleATO( true,Port2,360,0 );
        ReefAngel.StandardHeater( Port3,781,785 );
     // Turn Port5 on/off random cycles that lasts from 10 to 15 secs
        ReefAngel.StandardLights( Port7,21,0,23,0 );
        ReefAngel.StandardLights( Port8,21,0,9,0 );
      //  ReefAngel.DosingPumpRepeat( Box1_Port3,0,120,2 );
      //  ReefAngel.DosingPumpRepeat( Box1_Port4,5,120,3 );
	// Turn Port6 on/off on opposite cycle as Port 5
	/*AUTOFEED if the hour is 11a, minute is 55 and seconds is 0
              if ( ((hour() == 11) && (minute() == 55) && (second() == 00) ) )
    //Dose Ca
                  if ( ReefAngel.DisplayedMenu == DEFAULT_MENU ) //Ca Doser - Only works if Main screen is showing
                   /* && = and || = or
                   Hours between 12am and 5am
                   minute must be 0 (top of the hour)
                   seconds less than 2 (up to 2 seconds)
                   if ( ((hour() >= 0) && (hour() <= 6)) && (minute() == 0) && //dose time
                       (second() < 2) ) //dose duration
                      ReefAngel.Relay.On(CaDoser);
                      ReefAngel.Relay.Off(CaDoser);
    //Dose Alk
                       if ( ReefAngel.DisplayedMenu == DEFAULT_MENU ) //Alk Doser - Only works if Main screen is showing
                  /*  && = and || = or
                   Hours between 12:05am and 7:05am
                   seconds less than 3 (up to 3 seconds)
                  if ( ((hour() >= 0) && (hour() <= 7)) && (minute() == 5) && //dose time
                       (second() < 3) ) //dose duration
                      ReefAngel.Relay.On(AlkDoser);
                      ReefAngel.Relay.Off(AlkDoser);
    //Power Outage
       ReefAngel.CustomVar[0]=ReefAngel.Relay.IsRelayPresent(EXP1_RELAY);
    if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
        ReefAngel.Relay.Off (Port1);
        ReefAngel.Relay.Off (Port2);
        ReefAngel.Relay.Off (Port3);
        ReefAngel.Relay.Off (Port5);
        ReefAngel.Relay.Off (Port6);
        ReefAngel.Relay.Off (Port7);
        ReefAngel.Relay.Off (Port8);
        ReefAngel.Relay.Off (Daylight);   //port 1
        ReefAngel.Relay.Off (AutoTopOff); //port 2
        ReefAngel.Relay.Off (Heater);     //port 3
        ReefAngel.Relay.Off (WavemakerL); //port 5
        ReefAngel.Relay.Off (WavemakerR); //port 6
        ReefAngel.Relay.Off (WavemakerR); //port 7
        ReefAngel.Relay.Off (FugeLight);  //port 8
    if (!ReefAngel.HighATO.IsActive())
        ReefAngel.Relay.Off( Box1_Port6 );
   //ATO/HEATER PORTAL PORTAL ALERT
       if ( InternalMemory.read(ATO_Single_Exceed_Flag) == 1 )
        ReefAngel.CustomVar[1]=1;
        ReefAngel.CustomVar[1]=0;
        if ( InternalMemory.read(Overheat_Exceed_Flag) == 1 )
        ReefAngel.CustomVar[2]=1;
        ReefAngel.CustomVar[2]=0;
        ReefAngel.Portal( "chase", "2600" );
        int x,y;
        // Parameters
        ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
        ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
        // Salinity
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,54, "SAL:" );
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,54, ReefAngel.Params.Salinity );
        // Water Level
        ReefAngel.LCD.DrawText( COLOR_OLIVEDRAB,DefaultBGColor,75,54, "WL:" );
        ReefAngel.LCD.DrawText( COLOR_OLIVEDRAB,DefaultBGColor,94,54, ReefAngel.WaterLevel.GetLevel() );
        // Main Relay Box
        ReefAngel.LCD.DrawOutletBox( 12, 76, TempRelay );
        // Relay Expansion
        ReefAngel.LCD.DrawOutletBox( 12, 98, TempRelay );
        // Date and Time
Posted: Fri Oct 19, 2012 4:06 pm
My bad.
Change this:
To this:
Posted: Fri Oct 19, 2012 6:01 pm
by chase
Yep, that was it thanks again!
