Fresh start
Fresh start
How can I get the unit back to the factory default? I have reloded the sketch, but no new one's seem to work. I want to update the library and wipe the memory to be fresh for the new one.
Re: Fresh start
Did you use the Arduino and Click tools and Restore Preloaded Code? Never tried this I just happened to see it in the menu and thought I would ask..
Re: Fresh start
yes, this will restore the controller to the factory default settings.dbmet wrote:Did you use the Arduino and Click tools and Restore Preloaded Code? Never tried this I just happened to see it in the menu and thought I would ask..
Re: Fresh start
I did do that. But when I make a new sketch and upload it does not seem to be working. For example, I have port 7,8 always on for return & skimmer, but they stay off. I think I must have messed up the initial mem when I set it up months ago.
Re: Fresh start
Can you post the code that you uploaded that keeps ports 7 & 8 off? Internal memory does not affect ports that are marked as Always On.topjimmy wrote:I did do that. But when I make a new sketch and upload it does not seem to be working. For example, I have port 7,8 always on for return & skimmer, but they stay off. I think I must have messed up the initial mem when I set it up months ago.
Re: Fresh start
ReefAngel.StandardHeater( Port1,770,790 );
ReefAngel.StandardATO( Port2,120 );
ReefAngel.StandardLights( Port3,9,0,22,0 );
ReefAngel.WavemakerRandom( Port5,60,100 );
ReefAngel.WavemakerRandom( Port6,51,94 );
ReefAngel.PWM.SetDaylight( PWMParabola(9,40,21,30,0,100,0) );
ReefAngel.PWM.SetActinic( PWMParabola(9,0,22,0,0,100,0) );
Re: Fresh start
Where it shows Ports always on you don't have anything there or any where else that I saw..
Heres what I had for my ports that where always on --- You will need to change whatever ports you want.
ReefAngel.Relay.On( Port3 );
Re: Fresh start
yeah I noticed that too, but I did choose them in the wizard. So now I down loaded the new version, sent the config up and my screen says no internal memory found
Re: Fresh start
Oh, yeah...
There was a version way back that had that bug on the Wizard.
This was still a beta version of the Wizard.
Now that you updated the libraries, it should generate the correct code.
To go past the internal memory not found, you must upload the new InitialInternalMemory code.
File->Sketchbook->Example Codes->InitialInternalMemory
