Fresh start
Posted: Sun Oct 21, 2012 6:54 am
How can I get the unit back to the factory default? I have reloded the sketch, but no new one's seem to work. I want to update the library and wipe the memory to be fresh for the new one.
https://forum.reefangel.com/
yes, this will restore the controller to the factory default settings.dbmet wrote:Did you use the Arduino and Click tools and Restore Preloaded Code? Never tried this I just happened to see it in the menu and thought I would ask..
Can you post the code that you uploaded that keeps ports 7 & 8 off? Internal memory does not affect ports that are marked as Always On.topjimmy wrote:I did do that. But when I make a new sketch and upload it does not seem to be working. For example, I have port 7,8 always on for return & skimmer, but they stay off. I think I must have messed up the initial mem when I set it up months ago.
ReefAngel.OverheatShutoffPorts = Port1Bit;
ReefAngel.StandardHeater( Port1,770,790 );
ReefAngel.StandardATO( Port2,120 );
ReefAngel.StandardLights( Port3,9,0,22,0 );
ReefAngel.WavemakerRandom( Port5,60,100 );
ReefAngel.WavemakerRandom( Port6,51,94 );
ReefAngel.PWM.SetDaylight( PWMParabola(9,40,21,30,0,100,0) );
ReefAngel.PWM.SetActinic( PWMParabola(9,0,22,0,0,100,0) );
