Hi
Greeting everyone. I just got my new controller, It's Basic set.
Got some problem with code upload. Everytime I tried to upload sketch I alwasy got below
Copyright (c) 2000-2005 Brian Dean
Using Port : \\.\COM7
Using Programmer : stk500v1
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: Recv: 0 [30]
avrdude: stk500_getsync(): not in sync: resp=0x30
I had set board setting to Board --> Reef Angel controller
Anythink else do I need to set? (Programmer, Buad rate.) To make upload successful.
Please help
Thanks you
Program upload : not in sync problem
Re: Program upload : not in sync problem
Hirimai wrote:Choose Reef Angel Controller w/ optiboot
This is an error when I use the above option
Copyright (c) 2000-2005 Brian Dean,
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
Do you have standard RA or RA+???
Are you sure it is COM7?
Roberto he is using a standard RA 32krimai wrote:Do you have standard RA or RA+???
I think it is. As when connected USB com7 is automatic display in the list. And when I try to upload. It's does not complain on connection error at all.rimai wrote:Do you have standard RA or RA+???
No, Is is only 1 port to display and select.rimai wrote:Is there any other option besides COM7?
BTW
- what is programmer should I use currently default at AVRISP MrkII
- Anything to do with this --> Overriding Baud Rate : 115200
Is it should be --> 57600 If yse how to change it?
