Wifi setup trouble
Wifi setup trouble
Ok i tried to set my wifi up every way that there is.. that i know of that is.. i tried to wifi utility app, davem utility wifi app. which the only one that gave me any kinda luck was the RA app, it did read the module but could not connect i had given me two false's and could not find the router. i believe ive done everything right. but i switched to the other app to try.. i would not connect either. so i tried another computer and now both computers are telling me to reconnect the usb, so i unistalled the installer app to reset the ports.. still no luck, i was able to program the controller. any idea on whats going on.. is it the usb cable that is not working? I do have lights blinking green and blue, i also tried manual but it doesnt do anything after i set up the serial port. the black square just flashes
Re: Wifi setup trouble
If you were able to program the controller, it shouldn't be the cable.
Make sure the SSID and passphrase are case sensitive and that there is no $ sign. Also, space in the ssid may mess it up too.
Try changing it to WPA2-PSK with AES encryption.
my ssid and password are just letters it is also at WPA2-PSk.... i keep getting the please disconnect and reconnect error. but i do get it to work after a few reconnects.. but i get the two false msg after i connect
Opening Serial Port...
Verifying speed at 9600 baud
** ERROR: Connecting to COM10
** Error inside Serial.<init>()
Connected to serial port COM3
< $$$set u b 57600
> set u b 57600
< set s p 0
> set s p 0
< save
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM3
< $$$$$$set u b 57600
> set u b 57600
< set s p 0
> set s p 0
< save
> save
> reboot
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< reboot
Wifi is communicating at 9600 baud rate
> set u b 57600
> set s p 0
> save
< save
> reboot
Connected to serial port COM10
> set u b 57600
> set s p 0
> save
> reboot
Removing connection to COM10
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM10
< CMD
> ls
< ìs
< FL# SIZ FLAGS
< 11 19 3 WiFly_GSX-2.23
< 30 1 10 config
< 225 Free, Boot=11, Backup=11
< <2.23>
> set c c 0
< set c c 0
< AOK
< <2.23>
> set c r 0
< set c r 0
< AOK
< <2.23>
> set c o 0
< set c o 0
< AOK
< <2.23>
> set c i 3
< set c i°3
< AOK
< <2.23>
> set c s 1420
< set c s°3420
< AOK
< <2.23>
> set d n http://www.reefangel.com
< óeüd n http://www.reefangel.com
< AOK
< <2.23>
> set i h 198.171.134.6
< seti h 198.171.134.6
< AOK
< <2.23>
> set i r 80
< ·Ùº i r 80
< AOK
< <2.23>
> set i f 0x6
< set i f 0x6
< AOK
< <2.23>
> set s t 0x10
< set s t 0x10
< AOK
< <2.23>
> set u m 2
< set u m 2
< AOK
< <2.23>
> set i p 2
< set i p 2
< AOK
< <2.23>
> set o d ReefAngelWifi
< set o d ReeæAngelWifi
< AOK
< <2.23>
> set w l 5
< set w l 5
< AOK
< <2.23>
> set w s larhxxxxxxxx
< ÿÙº w s larhxxxxxxxx
< AOK
< <2.23>
> set w p larxxxxx
< set w p larxxxxx
< AOK
< <2.23>
< set w k°00000000000000000000000000
< AOK
< <2.23>
> set ftp address 198.175.253.161
< set ftp address 198¿Ì³3³³fY3³fÃÃAOK
< <2.23>
> save
< save
< Storing in config
< <2.23>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=larhxxxxx
< Chan=0
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <2.23>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=0.0.0.0:2000
< NM=255.255.255.0
< GW=0.0.0.0
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< BACKUP=0.0.0.0
< <2.23>
> reboot
< reboot
< $$$set u b 57600
> set u b 57600
< set s p 0
> set s p 0
< save
> save
> reboot
> set u b 57600
< set s p 0
> set s p 0
< save
> save
> reboot
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< reboot
> set u b 57600
> set s p 0
> save
< save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ìs
< FL# SIZ FLAGS
< 30 1 10 config
< <2.23>
> set c c 0
< set c c 0
< AOK
< <2.23>
> set c r 0
< set c r 0
< AOK
< <2.23>
> set c o 0
< set c o 0
< AOK
< <2.23>
> set c i 3
< set c i°3
< AOK
< <2.23>
> set c s 1420
< set c s°3420
< AOK
< <2.23>
< AOK
< <2.23>
< AOK
< <2.23>
> set i r 80
< ·Ùº i r 80
< AOK
< <2.23>
> set i f 0x6
< set i f 0x6
< AOK
< <2.23>
> set s t 0x10
< set s t 0x10
< AOK
< <2.23>
> set u m 2
< set u m 2
< AOK
< <2.23>
> set i p 2
< set i p 2
< AOK
< <2.23>
< AOK
< <2.23>
> set w l 5
< set w l 5
< AOK
< <2.23>
< AOK
< <2.23>
> set w p larxxxxx
< set w p larxxxxx
< AOK
< <2.23>
< AOK
< <2.23>
< <2.23>
> save
< save
< Storing in config
< <2.23>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=larhxxxxx
< Chan=0
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <2.23>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=0.0.0.0:2000
< NM=255.255.255.0
< GW=0.0.0.0
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< BACKUP=0.0.0.0
< <2.23>
> reboot
< reboot
lol.. new to this forum sorry for the accidental report.. any luck on whats going on with my wifi?
Is this a used RA?
I haven't seen that firmware in a while
Can you try Dave's app?
Make sure you use 57600 baud.
yes it is used.. i tried his but it wont do anything.. i will try again.. i thought that the firmware was out of date and i could upload one or there was a attachment for one.. i will try dave's app again though
ok i tried it.. it wont connect,
