Opening Serial Port...
Verifying speed at 9600 baud
** ERROR: Connecting to COM10
** Error inside Serial.<init>()
Connected to serial port COM3
< $$$set u b 57600
> set u b 57600
< set s p 0
> set s p 0
< save
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM3
< $$$$$$set u b 57600
> set u b 57600
< set s p 0
> set s p 0
< save
> save
> reboot
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< reboot
Wifi is communicating at 9600 baud rate
> set u b 57600
> set s p 0
> save
< save
> reboot
Connected to serial port COM10
> set u b 57600
> set s p 0
> save
> reboot
Removing connection to COM10
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM10
< CMD
> ls
< ìs
< FL# SIZ FLAGS
< 11 19 3 WiFly_GSX-2.23
< 30 1 10 config
< 225 Free, Boot=11, Backup=11
< <2.23>
> set c c 0
< set c c 0
< AOK
< <2.23>
> set c r 0
< set c r 0
< AOK
< <2.23>
> set c o 0
< set c o 0
< AOK
< <2.23>
> set c i 3
< set c i°3
< AOK
< <2.23>
> set c s 1420
< set c s°3420
< AOK
< <2.23>
> set d n
http://www.reefangel.com
< óeüd n
< AOK
< <2.23>
> set i h 198.171.134.6
< seti h 198.171.134.6
< AOK
< <2.23>
> set i r 80
< ·Ùº i r 80
< AOK
< <2.23>
> set i f 0x6
< set i f 0x6
< AOK
< <2.23>
> set s t 0x10
< set s t 0x10
< AOK
< <2.23>
> set u m 2
< set u m 2
< AOK
< <2.23>
> set i p 2
< set i p 2
< AOK
< <2.23>
> set o d ReefAngelWifi
< set o d ReeæAngelWifi
< AOK
< <2.23>
> set w l 5
< set w l 5
< AOK
< <2.23>
> set w s larhxxxxxxxx
< ÿÙº w s larhxxxxxxxx
< AOK
< <2.23>
> set w p larxxxxx
< set w p larxxxxx
< AOK
< <2.23>
< set w k°00000000000000000000000000
< AOK
< <2.23>
< set ftp address 198¿Ì³3³³fY3³fÃÃAOK
< <2.23>
> save
< save
< Storing in config
< <2.23>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=larhxxxxx
< Chan=0
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <2.23>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=0.0.0.0:2000
< NM=255.255.255.0
< GW=0.0.0.0
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< BACKUP=0.0.0.0
< <2.23>
> reboot
< reboot
