Original RA
jsclownfish
Original RA
Post by jsclownfish »
I need another IO outlet and I was thinking about my options. I could just order another IO expansion , but I only need one extra. I could run a wire to add a pin to the current IO (I think). But, since I am using my original RA as a secondary monitor, could I also use the ATO, pH, and Temp ports off of it and send the data to the main like the expansion modules? :geek:
Jon
Re: Original RA
Sure you can.
