Error with my code
xtown90
Error with my code
Post by xtown90 »
My code is given me an error not sure why. Can anyone help me out?
sketch_Mine:109: error: expected constructor, destructor, or type conversion before '.' token
sketch_Mine:110: error: expected constructor, destructor, or type conversion before '.' token
sketch_Mine:111: error: expected declaration before '}' token
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit;
    ReefAngel.WaterChangePortsE[0] = Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
    InternalMemory.OverheatTemp_write( 801 );
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.PWM.SetChannel(1,TunzeLongPulse(30,87,2,true));
    ReefAngel.PWM.SetChannel(0,TunzeLongPulse(30,87,2,true));
    ReefAngel.StandardATO( Port1,60 );
    ReefAngel.StandardHeater( Port7,740,780 );
    ReefAngel.StandardFan( Box1_Port2,780,781 );
    ReefAngel.StandardFan( Box1_Port3,780,781 );
    ReefAngel.DosingPumpRepeat( Box1_Port5,0,60,10 );
    ReefAngel.DosingPumpRepeat( Box1_Port6,0,60,10 );
    ReefAngel.PWM.SetDaylight(PWMSlope(11,30,21,0,0,70,180,0));
    ReefAngel.PWM.SetActinic(PWMSlope(11,0,22,0,0,90,180,0));
byte TunzeLongPulse(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  byte tspeed=0;
  PulseMinSpeed=constrain(PulseMinSpeed,0,100);
  PulseMaxSpeed=constrain(PulseMaxSpeed,0,100);
  tspeed=(now()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
  if (PulseSync)
    return tspeed;
    return (tspeed==PulseMinSpeed)?PulseMaxSpeed:PulseMinSpeed;
    ReefAngel.Portal( "xtown90" );
    int x,y;
    ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,54, "SAL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,54, ReefAngel.Params.Salinity );
    ReefAngel.LCD.DrawOutletBox( 12, 75, TempRelay );
    // Relay Expansion
    ReefAngel.LCD.DrawOutletBox( 12, 98, TempRelay );
Rob
Re: Error with my code
Yes, you have code that is out of place. This block of code:
Should be inside the loop() function. Instead, you closed off the loop and added a TunzeLongPulse function. Here's how the code should look:
  byte tspeed=0;
  if (PulseSync)
    return tspeed;
    int x,y;
    // Salinity
    // Relay Expansion
xtown90
Post by xtown90 »
Rob
