Anyway what i would like is somebody experienced to review my code. I have it controlling the tunzes for now since I cant really mess anything up in the tank with that but I'm scared to put everything on the controller until I have somebody look it over.
I want tunze control with a night mode which seems to be working
I want alk to dose on the hour between 11pm and 3pm the next day for ~1 minute
I dont know how big of a span I should give my heater does this look ok?
Ports are:
1 Heater
2 Cal Doser
3 Alk Doser
4 Return Pump
5 Right Tunze
6 Left Tunze
7 Actinic Leds
8 Mhs
Heres the code I'm using:
ReefAngel.FeedingModePorts = Port4Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port6Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 841 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
//Tunze short pulse functions
byte TunzeShortPulse(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
byte tspeed=0;
PulseMinSpeed=constrain(PulseMinSpeed,0,100);
PulseMaxSpeed=constrain(PulseMaxSpeed,0,100);
tspeed=(millis()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
if (PulseSync)
return tspeed;
return (tspeed==PulseMinSpeed)?PulseMaxSpeed:PulseMinSpeed;
ReefAngel.StandardHeater( Port1,807,813 );
ReefAngel.StandardLights( Port2,19,0,19,17 );
ReefAngel.StandardLights( Port7,15,0,23,0 );
ReefAngel.StandardLights( Port8,16,0,22,0 );
//night mode for tunzes
if ( (hour() >=23) || (hour() <=12) )
ReefAngel.PWM.SetActinic( TunzeShortPulse(30,30,10,true) );
ReefAngel.PWM.SetDaylight( TunzeShortPulse(30,50,5,false) );
//day mode for tunzes
ReefAngel.PWM.SetActinic( TunzeShortPulse(30,50,2,true) );
ReefAngel.PWM.SetDaylight( TunzeShortPulse(30,90,2,false) );
//Night time alk dosing
if ( ((hour() >= 23) || (hour() <= 15)) &&
(minute() == 0) &&
(second() <= 59) )
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.Off(Port3);
ReefAngel.AddWifi();
