Anyone fed the dimming port of a meanwell (ELN-60-48D) with the PWM signal from the RA? (ordered the PWM version of RA)
Does it work? (Think I read it will but the dimming won't be linear)
I've got the daylights on PWM dimmable drivers but am trying to use my old drivers for the actinic..
Also I read something about a jumper in the outlet box..
Can I just pull (or add) the jumper for the actinics channel only and have PWM (daylight) and analog (actinic)?
Meanwell "D" analog with PWM RA
Re: Meanwell "D" analog with PWM RA
Yes, the dimming will not be linear, but it will still dim.
The revision 8.1 is the only one that has such jumpers.
mcgyvr
and if I open the outlet box and see those jumpers will it work that I can have 1 channel analog and 1 PWM by pulling just one of the jumpers?rimai wrote:Yes, the dimming will not be linear, but it will still dim.
I assume there is no way to know which rev I have without opening it?
I ordered it on 10/16/2012
Yes, you can have one of each.
You will need to open it up.
I can't remember when I started shipping 8.1
mcgyvr
Thanks Roberto.rimai wrote:Yes, you can have one of each.
