Meanwell "D" analog with PWM RA
Posted: Thu Jan 03, 2013 9:55 am
by mcgyvr
Anyone fed the dimming port of a meanwell (ELN-60-48D) with the PWM signal from the RA? (ordered the PWM version of RA)
Does it work? (Think I read it will but the dimming won't be linear)
I've got the daylights on PWM dimmable drivers but am trying to use my old drivers for the actinic..
Also I read something about a jumper in the outlet box..
Can I just pull (or add) the jumper for the actinics channel only and have PWM (daylight) and analog (actinic)?
Re: Meanwell "D" analog with PWM RA
Posted: Thu Jan 03, 2013 10:21 am
Yes, the dimming will not be linear, but it will still dim.
The revision 8.1 is the only one that has such jumpers.
Posted: Thu Jan 03, 2013 10:26 am
by mcgyvr
rimai wrote:Yes, the dimming will not be linear, but it will still dim.
and if I open the outlet box and see those jumpers will it work that I can have 1 channel analog and 1 PWM by pulling just one of the jumpers?
I assume there is no way to know which rev I have without opening it?
I ordered it on 10/16/2012
Posted: Thu Jan 03, 2013 10:28 am
Yes, you can have one of each.
You will need to open it up.
I can't remember when I started shipping 8.1
Posted: Thu Jan 03, 2013 10:41 am
by mcgyvr
rimai wrote:Yes, you can have one of each.
Thanks Roberto.
