I am trying to set a 10min delay on a resume from power outage on my topoff port 3 on main relay box . Meaning would like for port 3 to wait 10 minutes before resuming normal operation after a power outage. This is the part of code I am talking about:
ReefAngel.SingleATO( true,Port3,60,1 );
ReefAngel.Relay.Off( Port3 );
I have read through the forums and seen where similar is being done with say a skimmer resuming from a power outage and / or feeding mode i.e. delayed start. Any help with how I might add just a simple delay for only this port would be highly appreciated.......
Delay on power up ?
- DrewPalmer04
Re: Delay on power up ?
ReefAngel.Relay.DelayedOn(Port3, 10);
This will delay port 3 for 10 min after a controller restart
- lnevo
Delay on power up ?
That will not work with the ato port..
That's like having the port be On and DelayedOn at the same time..
We have some code in another thread for delaying devices after power outage that you will probably need to implement.
- DrewPalmer04
Ah. Didn't understand the question. Yeah it won't work for that.
dmolton
Maybe something like this:
bool atoSpanReached; //flag to determine if the controller has been running long enough to start ATO functionality
if(!atoSpanReached)
if(millis() >= 600000) //Has program been running for 10 minutes?
atoSpanReached = true; //It has so the set the flag
if(atoSpanReached) //Only run the ATO operations if the flag has been set
