temp probe in another tank
rossbryant1956
Post by rossbryant1956 »
I am using this piece of code in my main tank:
ReefAngel.TempProbe = T1_PROBE;  // Set the 1st plug to monitor DT temp
    ReefAngel.OverheatProbe = T1_PROBE;  // to monitor the overheat and temperatures
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit;  // DT Lights and Heat turned off when Overheat temperature exceeded
       InternalMemory.OverheatTemp_write( 829 );
I now want to add another probe on the third port and monitor another tank separately. It will have separate heaters, lights etc. How do I do this, create a another overheat point on another probe and act independently
thx in advance
Re: temp probe in another tank
I think you already have that :)
Your own post:
http://forum.reefangel.com/viewtopic.php?p=17386#p17386
rossbryant1956
nope, I am bringing up a second tank and want another ( a second) overheat variable. One that runs in the first tank and a second one that runs in the other tank. Thx
It's going to be hard coded.
This functionality is not in the libraries.
You can use something like this:
if (ReefAngel.Params.Temp[T3_PROBE] > 830)
ReefAngel.Relay.Off(Port1);
rossbryant1956
that'll work, thx.
