My wifi usually only says online about 24 hours before I have to reset it. I read on another post that I should update my firmware. I tried to do this via the wifi utility and get the message below. I see where it states: UPDATE OK, should I assume the update occurred and the error message occurred after the fact?
Opening Serial Port...
Connected to serial port COM3
< CMD
> ftp u
< ftp u
< <2.38.3>
< FTP connecting to 198.175.253.161
< FTP file=68
< FTP OK.
< UPDATE OK
> ftp r wps.img
< ftp r wps.img
< <2.38.3>
< FTP file=34
< FTP OK.
< GET /r99 HTTP/1.1
< Host: xxxxxx
< Connection: Keep-Alive
< GET /r99 HTTP/1.1
< Host: xxxxxx
> reboot
Removing connection to COM3
WiFi Firmware Update Issue
Re: WiFi Firmware Update Issue
You have the client constantly trying to connect to the module which is probably what is causing it to generate that error, but I can see you already have latest 2.38.3 f/w version.
Thanks for taking a look.
Not sure why the persistent connection is happening, I just tried to update the firmware from the wifi utility. I didn't do anything manually or with the prompt.
I meant you have the Reef Angel Client app constantly trying to connect while you are trying to change settings.
This indicates the connection attempts
< GET /r99 HTTP/1.1
< Host: xxxxxx
