				Relay problem...
				Posted: Mon Jan 28, 2013 8:12 am
				by baroutas
				Hi! In my relay box, Port 4 (Standar lignhts) does not Work. The RA controler show me '' the Port is open'', but the lights does not open. Until now I have never  use the port 4. When i put the lights to an other open Port, the lights Open.
 This is a bug or relay problem?
				Re: Relay problem...
				Posted: Mon Jan 28, 2013 8:17 am
				by baroutas
				Also when i open and close the port 4 i can not hear the typical Clik that the relay does when open and close one Port.
 This is my code:
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit;
    InternalMemory.OverheatTemp_write( 350 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardHeater( Port1,278,280 );
    ReefAngel.StandardFan( Port2,310,320 );
    ReefAngel.StandardLights( Port3,13,50,22,0 );
    ReefAngel.StandardLights( Port4,15,30,19,0 );
    ReefAngel.DosingPumpRepeat( Port5,0,1240,10 );
    ReefAngel.StandardLights( Port6,20,30,23,59 );
    ReefAngel.PWM.SetDaylight( PWMSlope(14,0,21,0,10,100,15,10) );
    ReefAngel.PWM.SetActinic( PWMParabola(20,0,23,59,0,100,0) );
    ReefAngel.Portal( "xxxxxxxx" );
				Posted: Mon Jan 28, 2013 8:40 am
				If it's a bad port you'll need to verify using the Relay Box test software. Roberto can advise after that on RMA or other appropriate steps. Your code looks ok...
				Posted: Mon Jan 28, 2013 8:57 am
				by baroutas
				How can i verify the relay box? what are the steps and conections? Sory to asking so mutch....
				Posted: Mon Jan 28, 2013 9:19 am
				by DrewPalmer04
				Sketch-> examples->relay test?
				Posted: Mon Jan 28, 2013 9:20 am
				File->Sketchbook->Example Codes->ControllerTester
				Posted: Mon Jan 28, 2013 9:50 am
				by baroutas
				Ok i make the test and show me the prot 4 OPEN but the port does not open.... All the ather ports is Ok! Is anything i can do??
				Posted: Mon Jan 28, 2013 9:52 am
				Was it working before?
PM for RMA.
				Posted: Mon Jan 28, 2013 10:18 am
				by baroutas
				What is mean RMA?
				Posted: Mon Jan 28, 2013 10:25 am
				by DrewPalmer04
				DrewPalmer04 wrote:Sketch-> examples->relay test?
Sorry. Tried my best off memory
				Posted: Mon Jan 28, 2013 10:27 am
				by DrewPalmer04
				baroutas wrote:What is mean RMA?
Return merchandise authorization
 AKA to get it fixed!
				Posted: Mon Jan 28, 2013 10:41 am
				by baroutas
				Posted: Mon Jan 28, 2013 10:13 pm
				by 00Warpig00
				Could the VGA cable be missing a single connection?
Nick
				Posted: Tue Jan 29, 2013 7:57 am
				by baroutas
				I don't think show. I try to change the power relay (no 4) inside the main relay and if is not work then we will see!!!! Now i am in the midle of this work and i waet the spare part.....
				Posted: Tue Jan 29, 2013 1:32 pm
				by baroutas
				Ok!!! I replace the power relay iside main relay (with roberto instractions) and everythink works perfect!!It is very simle Think!!! Thanks Roberto!!
				Posted: Wed Jan 30, 2013 7:40 am
				by baroutas
				Hi! Today new problem With  relay box....!
 1. Stop working the relay 4. when i give them the order to open and close that does not responding!!
 2. When open and close  relay 2, open and close relay 4 and 6 All together!!!
 3. When open and close relay 6, open and close relay 2 and 4 all together!!!
 4. Also When i give an order to relay 2 and after i give an order to relay 6 that does not respond and the opposite! The relay 4 still responding  only when i give an order to the ather two relays!
Bug or damange from replaced relay?? Yesterday everethink works good
				Posted: Wed Jan 30, 2013 9:52 am
				That looks like your svga cable is shorted out.
I think it could even be the initial problem.
If you move the cable around, does it change anything?
				Posted: Wed Jan 30, 2013 11:12 am
				by baroutas
				I change the cable with a new one and everethink works perfect!!! Agains one THANKS!!
				Posted: Wed Jan 30, 2013 8:34 pm
				by 00Warpig00
				+1
				Posted: Thu Jan 31, 2013 8:03 am
				by baroutas
