Relay Port 7 not turning off
rossbryant1956
Post by rossbryant1956 »
I have recently revamped my code to begin adding a new tank, separately plumbed from my main tank, adding back my second relay, ph expansion, second heaters, etc., heading towards the code discussion on here of having the second box turn off during outages.
The problem I am having right now is that Port 7 will not turn off when told to. It used to be a heater port and is now an always-on port running the pump on the second tank. I believe I have it correctly programmed in my feeding, water change, etc., code statements but it will not go off.
I experimented today, turning off the port from the client, from the portal, etc. and although those devices say off, the pump is still running. I thought it had to do with my "always-on" statements but port 8, also set that way, operates normally. Please take a look at my code and see if you see something I don't. Thx
// Autogenerated file by RAGen (v1.2.1.158), (02/17/2012 22:55)
void setup() {
    ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Turn off DT-LWM, GT-LWM, GT-Pump, and DT-Pump when feeding mode is activated is activated on Box1
    ReefAngel.FeedingModePortsE[0] = Port5Bit | Port6Bit | Port7Bit; // Turn off DT-RWM, GT-RWM, and Skimmer when feeding mode is activated is activated on Box2
    ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port8Bit; // Turn off DT-Heat, DT-LWM, and DT-Pump when water change mode is activated
    ReefAngel.TempProbe = T1_PROBE;  // Set the 1st plug to be DT Main temp
    ReefAngel.OverheatProbe = T1_PROBE;  // to monitor the overheat and temperatures
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit;  // DT-Lights and DT-Heat turned off when Overheat temperature exceeded
    ReefAngel.OverheatShutoffPortsE[0] = Port7Bit; //Skimmer turned off if overheat
    InternalMemory.OverheatTemp_write( 829 ); // Set the DT Overheat temperature setting
    ReefAngel.Relay.On(Port8); // Turn on Pump
    ReefAngel.Relay.On(Port7); // Turn on GT Pump
    ReefAngel.Relay.On(Box1_Port8); // power the PH expansion hub
    // Specific functions
    ReefAngel.StandardLights( Port1,12,00,22,00 ); // Regular Lights on at 12:00pm and off at 10:00pm
    ReefAngel.StandardLights( Box1_Port3,12,00,21,45 );  //GT Lights Main 12:00pm - 9:45pm
    ReefAngel.StandardLights( Box1_Port4,13,00,22,30 ); //GT Lights Actinic 1:00pm - 10:30pm
    ReefAngel.WavemakerRandom( Port5,60,100 );
    ReefAngel.Relay.Set( Box1_Port5, !ReefAngel.Relay.Status( Port5 ) ); //Randomize DT powerheads
    ReefAngel.WavemakerRandom( Port6,60,100 );
    ReefAngel.Relay.Set( Box1_Port6, !ReefAngel.Relay.Status( Port6 ) ); //Randomize GT powerheads
    ReefAngel.StandardHeater(Port3,779,791);
    StandardHeater2( Port4,779,791 ); //GT-Heat
    // if the hour is 2p or 8p, minute is 55 and seconds is 0
	// start the feeding mode
		if ( ((hour() == 14) || (hour() == 20)) &&
		(minute() == 55) &&
		(second() == 0) )
		ReefAngel.FeedingModeStart();
     //turn off port 8 - main pump when switch is tripped and sound buzzer
     ReefAngel.Relay.Set(Port8,ReefAngel.IO.GetChannel(0));
     ReefAngel.PWM.SetDaylight(100-(ReefAngel.IO.GetChannel(0)*100));
     //tell the portal we have a overflow problem
     ReefAngel.CustomVar[0]=ReefAngel.IO.GetChannel(0);
     ReefAngel.CustomVar[7]=1;
     //set up dosing pump one to run twice a week for 4 minutes
     //ReefAngel.Relay.Set(Box1_Port2,((weekday()==1||weekday()==4) && hour()==14 && minute()<6));
     //ReefAngel.Relay.Set (Box1_Port3,(hour()%2==0)); //stir chemicals in water top off unit
    ReefAngel.Portal("rossbryant1956");
void StandardHeater2(byte HeaterRelay, int LowTemp, int HighTemp) //Heater for Grow Tank
    if (ReefAngel.Params.Temp[T3_PROBE] == 0) return;  // Don't turn the heater on if the temp is reading 0
    if (ReefAngel.Params.Temp[T3_PROBE] <= LowTemp && ReefAngel.Params.Temp[T3_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay);  // If sensor temperature <= LowTemp - turn on heater
    if (ReefAngel.Params.Temp[T3_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay);  // If sensor temperature >= HighTemp - turn off heater
  int x,y;
  // pH Expansion
  ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,66, ReefAngel.Params.PHExp );
  // Relay Expansion
rossbryant1956
Re: Relay Port 7 not turning off
Additional thoughts:
Looking at the portal, it hows where the relay thought it switched off, both during the normal feeding modes yesterday and today, and it showed where I was physically switching it off using the client app and the portal, but it did not go off.
Also, I am likely wrong but looking at the relay data on the portal for some reason the relay data is swapped, box 0 being on the bottom and box 1 being on top. I thought when I last used this second relay box, the data lined up correctly. Thx
Was it working before?
I think the relay may have gone bad and you will need to send it for repair.
PM for RMA.
