portal issues
portal issues
I'm having issues with the portal. I keep gettin an error message of "unreachable address." I can ascess through the app on my iphone and ipad. I have changed settings for my router to allow forwarding. Any ideas? I do have the older wifi without the button on it. I purchased everything 2 years ago and just setup last week. Don't know if that makes a difference.
Re: portal issues
If you go to http://www.yougetsignal.com/tools/open-ports/ and check on port 2000, does it say open?
Re: portal issues
just checked and it says it is closed.
- DrewPalmer04
Re: portal issues
Go into your router and set port 2000 to forward to your wifi ip and test again.
Re: portal issues
I'm having same problem but when I test my portal it is open. I can access it through my iphone app but not on portal page. Says unreachable address. Can anyone help?
Re: portal issues
check your wan address is the same as what you have in portal
this page tells you what ur wan ip is - up in the right hand corner of page
this page will also tell you how to forward a port in your modem - reefangel isn't in the list but do a manual entry and it will show you where to put ip addy and port
search google for portforward wont let me put website link????
if it has changed from what you had then change it in portal
you might have a dynamic ip which means this will happen everytime your modem re-connects to the net
i have this issue atm, gotta ring my ISP and change it to static and i wont have this issue
Re: portal issues
After your 3rd post, it willreefindownunder wrote:search google for portforward wont let me put website link????
Re: portal issues
nice, got mine working in about 1 hour from opening the box was so happy, picking up my 2 x radions today
