portal issues
Posted: Mon Feb 18, 2013 7:43 am
by kclewis
I'm having issues with the portal. I keep gettin an error message of "unreachable address." I can ascess through the app on my iphone and ipad. I have changed settings for my router to allow forwarding. Any ideas? I do have the older wifi without the button on it. I purchased everything 2 years ago and just setup last week. Don't know if that makes a difference.
Re: portal issues
Posted: Mon Feb 18, 2013 8:52 am
If you go to
http://www.yougetsignal.com/tools/open-ports/ and check on port 2000, does it say open?
Re: portal issues
Posted: Mon Feb 18, 2013 9:07 am
by kclewis
just checked and it says it is closed.
Re: portal issues
Posted: Mon Feb 18, 2013 9:50 am
by DrewPalmer04
Go into your router and set port 2000 to forward to your wifi ip and test again.
Re: portal issues
Posted: Sun Apr 14, 2013 8:52 pm
by Chef Rob
I'm having same problem but when I test my portal it is open. I can access it through my iphone app but not on portal page. Says unreachable address. Can anyone help?
Re: portal issues
Posted: Thu Apr 18, 2013 2:05 pm
by reefindownunder
check your wan address is the same as what you have in portal
this page tells you what ur wan ip is - up in the right hand corner of page
this page will also tell you how to forward a port in your modem - reefangel isn't in the list but do a manual entry and it will show you where to put ip addy and port
search google for portforward wont let me put website link????
if it has changed from what you had then change it in portal
you might have a dynamic ip which means this will happen everytime your modem re-connects to the net
i have this issue atm, gotta ring my ISP and change it to static and i wont have this issue
Re: portal issues
Posted: Thu Apr 18, 2013 2:07 pm
reefindownunder wrote:search google for portforward wont let me put website link????
After your 3rd post, it will
Re: portal issues
Posted: Thu Apr 18, 2013 2:15 pm
by reefindownunder
nice, got mine working in about 1 hour from opening the box was so happy, picking up my 2 x radions today
