Problems communicating with RA+
Hi,
I just got the RA+ and was following up instructions in the manual like a good boy. I connected the RA+ to my Mac after installing all the latest SW (Reef Angel 1.0.2 upgraged to 1.0.3) and the FTDIUSBSerialDriver_10_4_10_5_10_6.
I selected: Tools>Board>Reef Angel Plus Controller and Tools>Serial Port>/dev/tty.usbserial-A901MIEL
The unit is connected using the appropriate pins on the head unit, and I've tried it powered with the relay box or the USB connected to the middle temp sensor.
When I open File>Sketchbook>Example Codes>InitialInternalMemory, and hit upload, the code compiles but it times out while sending the code to the unit.
This is the output on the IDE:
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 7,414 bytes (of a 258,048 byte maximum)
BTW, I've tried this on 2 different Macs using 2 different Mac OS X versions. Hopefully I'm missing some silly step.
Also I've tried Tools>Serial Monitor. No luck. The unit does not reboot when that window is opened or closed.
Thanks.
Watchdog Timer
Version Menu
Simple Menu
Thanks.
Re: Problems communicating with RA+
At the top of the program. Go to tools, board, and select ra+
yeap - that's one of the settings I posted
Does the controller reboot a few seconds after you hit upload?
It should happen when you see the message "Rebooting Reef Angel Controller"
nothing happens - it behaves as it is not been seen by the Mac
With the cable connected to RA, plug and unplug the usb end from the computer. Does it reboot now?
nope - USB cable busted?
wait - it rebooted this time
but still no dice - it won't load the code
Just tried the new USB cable. Problem solved.
Thanks Roberto.
Thanks Roberto.
Awesome!!!
So, when are we going to have a Reef Angel Client for Mac??
I'm sure there are a lot of other users wanting this!!!
This is the one for Windows:
http://forum.reefangel.com/viewtopic.php?f=8&t=2103
Do we have a talented mac developer in the house...
