Basic capacitive water level sensor
HodagReef
Post by HodagReef »
I’m looking at these sensors as safety device to control the operation of the pumps (return pump, ATO pump, and close loop pump). I like that they can be attached on the outside of tanks. Would these sensor work with the RA? How would they be wired to the RA? Has anybody used these types of sensors, if so any feedback?
Troy
CD50CNF06NO[1].pdf
PDF of sensor
(19.27 KiB) Downloaded 382 times
Re: Basic capacitive water level sensor
I think it should work just fine in one of the ATO ports.
jsclownfish
Post by jsclownfish »
Do these attach to the outside of the tank to detect water level?
-Jon
I have some of these I plan to hook up to detect leaks, but I think these function differently.
Link was disabled by the request of the website owner. He did not want us to link to his website.If you wish to go to their page, you can copy and paste the link and change home-securitystore to homesecuritystore
Should work fine too :)
HodagReef
Post by HodagReef »
Jon, yes these are glued on the outside of a tank.
Rimai, This a 3-wire DC sensor. Would this still work in the ATO ports?
Just make sure you get the 5VDC version.
If I understood correctly, the 3rd wire is going to give you 5VDC level signal, which can be used on the ATO port just fine.
markywmson
Post by markywmson »
Hey Troy
Cool find. If you get this up and running, I'd love to see the setup. Looks way more reliable (maybe?) than a float switch. Will be following along with this.
-mark
