Wave patterns
Wave patterns
I'd like to start a thread to collect all the efforts of creating wave patterns for controllable pumps.
These functions can be used for either Tunzes or Jebao pumps.
This list will keep being updated as we code more and more functions.
Short Pulse
PulseMinSpeed - % for minimal speed
PulseMaxSpeed - % for maximum speed
PulseDuration - Duration (milliseconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
PulseSync - true if you want to sync pumps to same cycle. one false and one true if you want to anti-sync pumps.
byte ShortPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  byte tspeed=0;
  PulseMinSpeed=constrain(PulseMinSpeed,30,100);
  PulseMaxSpeed=constrain(PulseMaxSpeed,30,100);
  tspeed=(millis()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
  if (PulseSync)
    return tspeed;
    return (tspeed==PulseMinSpeed)?PulseMaxSpeed:PulseMinSpeed;
Long Pulse
PulseDuration - Duration (seconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
byte LongPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  byte tspeed=0;
  tspeed=(now()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
  if (PulseSync)
    return tspeed;
Sine
Contribution of Discocarp
http://forum.reefangel.com/viewtopic.ph ... 86&p=18240
PulseDuration - Duration (seconds) in which the entire sine wave will take to complete.
byte SineMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync) {
  double x,y;
  x=double(now()%(PulseDuration));
  x/=PulseDuration;
  x*=2.0*PI;
  if (!PulseSync) x+=PI; // shift the sine wave for the right pump
  y=sin(x);// y is now between -1 and 1
  y+=1.0; // y is now between 0 and 2
  y/=2.0; // y is now between 0 and 1
  // now compute the tunze speed
  y*=double(PulseMaxSpeed-PulseMinSpeed);
  y+=double(PulseMinSpeed);
  y+=0.5; // for proper rounding
  // y is now between PulseMinSpeed and PulseMaxSpeed, constrain for safety
  return constrain(byte(y),30,100);
ReefCrest
WaveSpeed - % for average speed
WaveOffset - Max offset of speed in which the mode will go up/down from average speed
byte ReefCrestMode(byte WaveSpeed, byte WaveOffset, boolean PulseSync)
  static unsigned long lastwavemillis=millis();
  static int newspeed=WaveSpeed;
  if ((millis()-lastwavemillis) > 5000)
    if (random(100)<50) newspeed--; else newspeed++;
    newspeed=constrain(newspeed,WaveSpeed-WaveOffset,WaveSpeed+WaveOffset);
    newspeed=constrain(newspeed,0,100);
  if (PulseSync)
    return newspeed;
    return WaveSpeed-(newspeed-WaveSpeed);
Nutrient Transport
byte NutrientTransportMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  static byte WavePhase=0;
  static time_t WaveStart=0;
  static byte speed=PulseMinSpeed;
  static byte anti_speed=PulseMinSpeed;
  if (WavePhase==0)
    WavePhase++;
    WaveStart=now();
  else if (WavePhase==1)
    if (now()-WaveStart>2700)
      WavePhase++;
    if ((millis()-lastwavemillis) > PulseDuration)
      if (speed==PulseMinSpeed)
        speed=PulseMaxSpeed;
        anti_speed=PulseMaxSpeed;
  else if (WavePhase==2)
    if (now()-WaveStart>4500) WavePhase++;
    if (now()-WaveStart<=2760)
    if (now()-WaveStart<=3300)
      anti_speed=PulseMaxSpeed*sin(radians(map(now()-WaveStart,3300,4500,0,180)));
  else if (WavePhase==3)
    if (now()-WaveStart>7200) WavePhase++;
  else if (WavePhase==4)
    if (now()-WaveStart>9000) WavePhase=0;
    if (now()-WaveStart<=7260)
    if (now()-WaveStart<=8400)
      anti_speed=PulseMaxSpeed*sin(radians(map(now()-WaveStart,7200,8400,0,180)));
      anti_speed=0;
  if (PulseSync)
    return speed;
    return anti_speed;
Tidal Swell Mode
WaveMaxSpeed - % for maximum speed
byte TidalSwellMode(byte WaveMaxSpeed, boolean PulseSync)
  static byte speed=0;
  static byte anti_speed=0;
  if (WavePhase==0)
    WavePhase++;
    WaveStart=now();
    if (now()-WaveStart>900) WavePhase++;
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,0,900,0,90))))/10;
    speed+=WaveMaxSpeed/2;
    anti_speed=(WaveMaxSpeed*2*sin(radians(map(now()-WaveStart,0,900,0,90))))/5;
    anti_speed+=WaveMaxSpeed/2;
    if (now()-WaveStart>1800) WavePhase++;
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,900,1800,90,180))))/20;
    speed+=WaveMaxSpeed/20;
    anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,900,1800,90,180))))/20;
    anti_speed+=WaveMaxSpeed/4;
    if (now()-WaveStart>2700) WavePhase++;
    speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,1800,2700,0,90))))/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,1800,2700,0,90))))/20;
    if (now()-WaveStart>3600) WavePhase++;
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,2700,3600,90,180))))/20;
    speed+=(WaveMaxSpeed*3)/20;
    anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,2700,3600,90,180))))/20;
    anti_speed+=(WaveMaxSpeed*3)/20;
  else if (WavePhase==5)
    speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,3600,4500,0,90))))/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,3600,4500,0,90))))/20;
  else if (WavePhase==6)
    if (now()-WaveStart>5400) WavePhase++;
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,4500,5400,90,180))))/20;
    speed+=(WaveMaxSpeed*5)/20;
    anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,4500,5400,90,180))))/20;
    anti_speed+=WaveMaxSpeed/20;
  else if (WavePhase==7)
    if (now()-WaveStart>6300) WavePhase++;
    speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,5400,6300,0,90))))/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,5400,6300,0,90))))/20;
  else if (WavePhase==8)
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,6300,7200,90,180))))/20;
    speed+=(WaveMaxSpeed*7)/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,6300,7200,90,180))))/10;
  else if (WavePhase==9)
    if (now()-WaveStart>8100) WavePhase++;
    speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,7200,8100,0,90))))/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,7200,8100,0,90))))/2;
  else if (WavePhase==10)
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,8100,9000,90,180))))/2;
    anti_speed=speed;
  if (PulseSync)
    return speed;
    return anti_speed;
Tide Mode
Contribution of lnevo
http://forum.reefangel.com/viewtopic.php?f=11&t=2708
minOffset - minimum offset between high/low tide
maxOffset - maximum offset between high/low tide
byte TideMode(byte WaveSpeed, byte minOffset, byte maxOffset)
  // Contribution of lnevo
  double moonOffset; // gap between high and low
  double amplitude;  // tide curve
  double wavelength=12*SECS_PER_HOUR;
  // Calculate the gap between high and low tide based on MoonPhase()
  moonOffset=cos(((2*PI)/100)*MoonPhase());
  moonOffset=((moonOffset+1)/2)*100; // Convert to percentage
  // Find out the current tidal height
  amplitude=sin(((2*PI)/wavelength)*now());
  moonOffset=map(moonOffset,0,100,minOffset,maxOffset);
  amplitude=amplitude*moonOffset;
  // Adjust the calculate speed to be in our adjusted range
  return constrain(WaveSpeed+amplitude,0,100);
Wave patterns
The tide simulation class could be counted as a "constant" wave pattern similar to the Sine wave function above. It returns a constant speed that gives a high tide and low tide effect every 12 hours. The minOffset is the difference between high and low tide during quarter moons and the maxOffset is the difference at new and full moon.
Tide mode:
Speed - base midline speed for wave
minOffset - minimum gap between high/low tide
maxOffset - maximum gap between high/low tide
#define PI 3.141593
byte TideMode(byte Speed, byte minOffset, byte maxOffset) {
  amplitude=sin(((2*PI)/waveLength)*now());
  return constrain(Speed+amplitude,0,100);
Also should note that these functions could also be used with the Vortech custom mode :)
Edit: Updated to fix the broken map (did not like 0-1)..
Re: Wave patterns
fantastic! I like info on one page!
Piper
Re: Wave patterns
Post by Piper »
Very nice! Thanks, Roberto!!
treetopflyn
Re: Wave patterns
Post by treetopflyn »
Awesome. Thank you.
VSpeck
Wave patterns
Post by VSpeck »
Thanks this is awesome.
mudcat1
Re: Wave patterns
Post by mudcat1 »
Roberto, this is a great idea! You are really going to save new Reef Angel users a lot of time with this post. Thinking back on the countless hours that I spent researching this information in various threads when I got my Tunze powerhead.
Smotz
Re: Wave patterns
Post by Smotz »
excellent resource
Seedlessone
Re: Wave patterns
Post by Seedlessone »
So does anyone have a favorite yet?
Seedlessone
Re: Wave patterns
So is reef crest just a slow ramp up and down to the predefined range?
Seems to slow for me. Would like it to change values up and down faster.
Are there any aggressive modes? I loved the else mode.
Re: Wave patterns
Seedlessone wrote:So is reef crest just a slow ramp up and down to the predefined range?
Change   if ((millis()-lastwavemillis) > 5000) to any value >5000 so 4000, 3000 etc
That'll speed you up on how often it checks for random -- else ++
Re: Wave patterns
You can do short pulse mode with random range. Would that work?
Smotz
Re: Wave patterns
Post by Smotz »
rimai wrote:You can do short pulse mode with random range. Would that work?
Can you give me an example of this code?
Re: Wave patterns
ReefAngel.PWM.SetActinic(ShortPulseMode(0, 100, random(500,1500), true));
Smotz
Re: Wave patterns
Post by Smotz »
As always, much appreciated.
I know the 0 to 100 means between 0 and 100% power - I would want to limit that to 70% max so I would make mine 70.
The 500,1500 is duration in milliseconds?
Re: Wave patterns
Correct :)
You can also change the duration to whatever range you prefer.
Smotz
Re: Wave patterns
Post by Smotz »
So I set this code but it's not giving me the desired effect:
ReefAngel.PWM.SetDaylight( LongPulseMode(random(35,70),70,5,true));
what is does is quickly go through a bunch of random numbers, then it stays at 70% for 5 seconds.
What I wanted is for it to choose a random strength between 35 and 70% for 5 seconds.
Thoughts?
Re: Wave patterns
I see now that this solution will not work.
Try this:
byte random_speed=35;
if (now()%5==1) random_speed=random(35,70);
ReefAngel.PWM.SetDaylight( LongPulseMode(random_speed,70,5,true));
Smotz
Re: Wave patterns
Post by Smotz »
rimai wrote:I see now that this solution will not work.
Try this:
Any way to incorporate a pause (1 second) before the next pulse?
Re: Wave patterns
Not with this function.
You will need to use another custom function with whatever wave pattern you want.
Let me see if I understand...
The wave is going to be random between 35% and 70% for 5 seconds, 70% for 5 seconds and 0% for 1 second?
Weird one :roll: , but we can definitely do it... :mrgreen:
Smotz
Re: Wave patterns
Post by Smotz »
rimai wrote:Not with this function.
I guess. I am just trying to (logically) figure out a wave pattern with just 1 pump (and the return pump)
Re: Wave patterns
Add this to the end of your code:
byte MyCustomWave(byte maxspeed)
  static byte randomspeed=0;
  if (now()%11<5)
    return randomspeed;
  else if (now()%11>=5 && now()%11<10)
    return maxspeed;
    randomspeed=random(35,maxspeed);
    return 0;
And call your function like this:
  ReefAngel.PWM.SetActinic(MyCustomWave(70));
Smotz
Re: Wave patterns
Post by Smotz »
rimai wrote:Add this to the end of your code:
  if (now()%11<5)
    return randomspeed;
    return maxspeed;
    return 0;
Wow man, Thanks!
Can I ask you to help me understand this a bit? - Teach a man to fish sort of thing?
Can you explain what the %11 is? I assume it's the variable for the duration but I don't understand how it got defined..?
How would I alter this to Random wave, pause for 1 sec, etc ?
would this do it? (but it looks to me like it waits for 5 seconds?)
if (now()%11<5)
return randomspeed;
return 0;
Re: Wave patterns
The %11 is a mathematical computation. The % is actually called modulus. It takes the remainder of the division operation. When he is using the %11, he is taking the number of seconds (now()) and breaking it down into 11 segments with each segment being 1 second. The first part of his code, now()%11<5 is checking for seconds 0-4 inclusive (which is 5 seconds). The second part, now()%11>=5 && now()%11<10, is checking for seconds 5-9 inclusive (which is 5 seconds) and then the last scenario is simply 1 second.
What ends up happening is the first IF runs for 5 seconds, the next IF runs for 5 seconds and the last IF runs for 1 second then the whole process repeats over and over again every 11 seconds no matter what time of day it is.
Your code you put down:
if ( now()%11 < 5 )
return randomspeed;
return 0;
Will run the first part for 5 seconds and the second part for 6 seconds. So run for 5 seconds, pause for 6 seconds, repeat.
Smotz
Re: Wave patterns
Post by Smotz »
thanks curt. Much appreciated. I kinda get it - doing will really teach me. I am so glad i went reef angel. I am learning a lot.
Wave patterns
Smotz wrote:thanks curt. Much appreciated. I kinda get it - doing will really teach me. I am so glad i went reef angel. I am learning a lot.
+1 try doing any of this with an apex! Not possible!
Smotz
Re: Wave patterns
Post by Smotz »
binder wrote:The %11 is a mathematical computation. The % is actually called modulus. It takes the remainder of the division operation. When he is using the %11, he is taking the number of seconds (now()) and breaking it down into 11 segments with each segment being 1 second. The first part of his code, now()%11<5 is checking for seconds 0-4 inclusive (which is 5 seconds). The second part, now()%11>=5 && now()%11<10, is checking for seconds 5-9 inclusive (which is 5 seconds) and then the last scenario is simply 1 second.
if ( now()%11 < 5 )
return randomspeed;
return 0;
SOOO. If I change the 11 to a 7 - the first part will run for 5 seconds and the second for 2?
Re: Wave patterns
that is correct.
Robert1969
Re: Wave patterns
Post by Robert1969 »
ok Im a little lost. have had my WP40 cable for about a week and thought I would try to get my Jabao pump set up.
If I understand it correctly all I have to do is add a code from page 1, of this topic, between the lines "Place your custom code below/above here" on my sketch.
I can add this code from page 2 and it works fine:
But if I add lets say the "Reefcrest" code from page 1:
  if (PulseSync)
    return newspeed;
I get the following error from Arduino: a function-definition is not allowed here before{token
Do I need to do something to the code before adding it to my sketch?
Thanks for any help
Smotz
Re: Wave patterns
Post by Smotz »
The definition (the latter part) is longer needed in the updated libraries
