Controlling Jebao/Tunze/Speedwave pumps
Would you like to help?
Hi Everyone,
With the libraries v1.0.4 release, all the wave pattern functions are already included. I'm still keeping the previous post at the bottom for reference, but please consider it deprecated and don't use it anymore.
If you followed the previous post prior to v1.0.4, you will need to remove all that code you added at the bottom of your code or you will get a lot of errors with the new update.
If this is your first time, all you need to do is choose which wave pattern you would like to use in the thread below and call it in your code.
http://forum.reefangel.com/viewtopic.php?f=7&t=2844
For this example, we will use ReefCrest wave pattern at speed 60% with +/- 20%, which will give you a range of 40% to 80%.
Inside your loop() section of your INO code, you will see a section like this:
You must place the wave pattern code between those two comment lines. It will end up being like this:
    ReefAngel.PWM.SetDaylight( ReefCrestMode(60,20,true) ); // ReefCrest at 60% +/- 20% on sync mode
    ReefAngel.PWM.SetActinic( ReefCrestMode(60,20,false) ); // ReefCrest at 60% +/- 20% on anti-sync mode
The above lines will place your daylight channel in sync mode and actinic channel in anti-sync mode.
Upload your code and watch your Jebao or Tunze pumps being controlled by your Reef Angel.
Enjoy :)
Original post just for reference. Do not use this anymore.
Hi Everyone,
With the Jebao cables coming out and several members already getting them and getting very confused on how to get the pumps to work with the cable, I decided to put this little tutorial. This tutorial can be used for both Jebao and Tunze pumps.
Because the code used in this tutorial are not yet released together with our libraries, this is a temporary tutorial.
So, this will be updated as the libraries get updated.
Let's get coding....
The first thing you want to do is copy and paste this code to the very end of your INO code. You will see that the last line of your code will be a }. Paste after the last bracket.
byte ShortPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  byte tspeed=0;
  PulseMinSpeed=constrain(PulseMinSpeed,30,100);
  PulseMaxSpeed=constrain(PulseMaxSpeed,30,100);
  tspeed=(millis()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
  if (PulseSync)
    return tspeed;
    return (tspeed==PulseMinSpeed)?PulseMaxSpeed:PulseMinSpeed;
byte LongPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  byte tspeed=0;
  tspeed=(now()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
  if (PulseSync)
    return tspeed;
byte SineMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync) {
  double x,y;
  x=double(now()%(PulseDuration));
  x/=PulseDuration;
  x*=2.0*PI;
  if (!PulseSync) x+=PI; // shift the sine wave for the right pump
  y=sin(x);// y is now between -1 and 1
  y+=1.0; // y is now between 0 and 2
  y/=2.0; // y is now between 0 and 1
  // now compute the tunze speed
  y*=double(PulseMaxSpeed-PulseMinSpeed);
  y+=double(PulseMinSpeed);
  y+=0.5; // for proper rounding
  // y is now between PulseMinSpeed and PulseMaxSpeed, constrain for safety
  return constrain(byte(y),30,100);
byte ReefCrestMode(byte WaveSpeed, byte WaveOffset, boolean PulseSync)
  static unsigned long lastwavemillis=millis();
  static int newspeed=WaveSpeed;
  if ((millis()-lastwavemillis) > 5000)
    if (random(100)<50) newspeed--; else newspeed++;
    newspeed=constrain(newspeed,WaveSpeed-WaveOffset,WaveSpeed+WaveOffset);
    newspeed=constrain(newspeed,0,100);
  if (PulseSync)
    return newspeed;
    return WaveSpeed-(newspeed-WaveSpeed);
byte NutrientTransportMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  static byte WavePhase=0;
  static time_t WaveStart=0;
  static byte speed=PulseMinSpeed;
  static byte anti_speed=PulseMinSpeed;
  if (WavePhase==0)
    WavePhase++;
    WaveStart=now();
  else if (WavePhase==1)
    if (now()-WaveStart>2700)
      WavePhase++;
    if ((millis()-lastwavemillis) > PulseDuration)
      if (speed==PulseMinSpeed)
        speed=PulseMaxSpeed;
        anti_speed=PulseMaxSpeed;
  else if (WavePhase==2)
    if (now()-WaveStart>4500) WavePhase++;
    if (now()-WaveStart<=2760)
    if (now()-WaveStart<=3300)
      anti_speed=PulseMaxSpeed*sin(radians(map(now()-WaveStart,3300,4500,0,180)));
  else if (WavePhase==3)
    if (now()-WaveStart>7200) WavePhase++;
  else if (WavePhase==4)
    if (now()-WaveStart>9000) WavePhase=0;
    if (now()-WaveStart<=7260)
    if (now()-WaveStart<=8400)
      anti_speed=PulseMaxSpeed*sin(radians(map(now()-WaveStart,7200,8400,0,180)));
      anti_speed=0;
  if (PulseSync)
    return speed;
    return anti_speed;
byte TidalSwellMode(byte WaveMaxSpeed, boolean PulseSync)
  static byte speed=0;
  static byte anti_speed=0;
  if (WavePhase==0)
    WavePhase++;
    WaveStart=now();
    if (now()-WaveStart>900) WavePhase++;
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,0,900,0,90))))/10;
    speed+=WaveMaxSpeed/2;
    anti_speed=(WaveMaxSpeed*2*sin(radians(map(now()-WaveStart,0,900,0,90))))/5;
    anti_speed+=WaveMaxSpeed/2;
    if (now()-WaveStart>1800) WavePhase++;
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,900,1800,90,180))))/20;
    speed+=WaveMaxSpeed/20;
    anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,900,1800,90,180))))/20;
    anti_speed+=WaveMaxSpeed/4;
    if (now()-WaveStart>2700) WavePhase++;
    speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,1800,2700,0,90))))/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,1800,2700,0,90))))/20;
    if (now()-WaveStart>3600) WavePhase++;
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,2700,3600,90,180))))/20;
    speed+=(WaveMaxSpeed*3)/20;
    anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,2700,3600,90,180))))/20;
    anti_speed+=(WaveMaxSpeed*3)/20;
  else if (WavePhase==5)
    speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,3600,4500,0,90))))/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,3600,4500,0,90))))/20;
  else if (WavePhase==6)
    if (now()-WaveStart>5400) WavePhase++;
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,4500,5400,90,180))))/20;
    speed+=(WaveMaxSpeed*5)/20;
    anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,4500,5400,90,180))))/20;
    anti_speed+=WaveMaxSpeed/20;
  else if (WavePhase==7)
    if (now()-WaveStart>6300) WavePhase++;
    speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,5400,6300,0,90))))/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,5400,6300,0,90))))/20;
  else if (WavePhase==8)
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,6300,7200,90,180))))/20;
    speed+=(WaveMaxSpeed*7)/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,6300,7200,90,180))))/10;
  else if (WavePhase==9)
    if (now()-WaveStart>8100) WavePhase++;
    speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,7200,8100,0,90))))/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,7200,8100,0,90))))/2;
  else if (WavePhase==10)
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,8100,9000,90,180))))/2;
    anti_speed=speed;
  if (PulseSync)
    return speed;
    return anti_speed;
byte TideMode(byte WaveSpeed, byte minOffset, byte maxOffset)
  // Contribution of lnevo
  double moonOffset; // gap between high and low
  double amplitude;  // tide curve
  double wavelength=12*SECS_PER_HOUR;
  // Calculate the gap between high and low tide based on MoonPhase()
  moonOffset=cos(((2*PI)/100)*MoonPhase());
  moonOffset=((moonOffset+1)/2)*100; // Convert to percentage
  // Find out the current tidal height
  amplitude=sin(((2*PI)/wavelength)*now());
  moonOffset=map(moonOffset,0,100,minOffset,maxOffset);
  amplitude=amplitude*moonOffset;
  // Adjust the calculate speed to be in our adjusted range
  return constrain(WaveSpeed+amplitude,0,100);
Now, you must choose which wave pattern you wish to use. Please check this thread for the list of all wave patterns:
Enjoy :)
Seedlessone
Re: Controlling Jebao/Tunze pumps
Post by Seedlessone »
Awesome Roberto.
Smotz
Post by Smotz »
thank you for this
johniii
Post by johniii »
Works great. Thanks fellas
johniii
Post by johniii »
How would I select modes randomly?
Or maybe on a schedule?
You could do something like this:
if (hour()>=8 && hour()<12)
else if (hour()>=12 && hour()<18)
  ReefAngel.PWM.SetDaylight( ShortPulseMode(0,60,200,true) ); // Short pulse at 60% with 200ms pulse on sync mode
  ReefAngel.PWM.SetActinic( ShortPulseMode(0,60,200,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
  ReefAngel.PWM.SetDaylight( LongPulseMode(0,60,10,true) ); // Long pulse at 60% with 10s pulse on sync mode
  ReefAngel.PWM.SetActinic( LongPulseMode(0,60,10,false) ); // Long pulse at 60% with 10s pulse on anti-sync mode
johniii
Post by johniii »
rimai wrote:You could do something like this:
Your the man Roberto
Smotz
Post by Smotz »
Sorry for the n00b question.
I don't see the :
Where can I find that ?
It should be in the loop function after you use the wizard...
If not just make sure it is before the ShowInterface and Portal function.
Smotz
Post by Smotz »
Thank you - I see it's not in the preloaded code but it was there when I used the Wizard.
Sebyte
Post by Sebyte »
I would love to get one of these pumps going but don't have any free PWM ports, or do I?
I am using the Water level expansion so I do have the two ATO ports free and I seem to remember that they can provide a 0-5v PWM output.
I guess the question is would this output be sufficient to drive the the pump? If so how would the above code need to be changed to get the ATO ports in to use.
Only one ATO port can do PWM.
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,ReefCrestMode(60,20,true)*2.55);
The cable is designed to work on 0-10VDC signals.
You will need to mod the cable if you want to use 0-5VDC signal.
Take one resistor and bridge the pads instead.
Edited: Pads do not need to be bridged. Only removal of resistor R2 is necessary
Sebyte
Post by Sebyte »
Thanks, I thought that was the case. As I have not seen the cable harnes I am not sure what you mean by bridge the pads?
Any chance of a circuit diagram?
Many thanks
Remove R2.
Sebyte
Post by Sebyte »
Thanks Roberto
I will get a pump sent over and the place an order for cable and a couple of other bits as well.
Thanks again
mluz
Post by mluz »
First I would like to thank you all for the great info and help. I've owned my RA for about three weeks and I found everything I needed to get it running in this forum.
I also bought a WP40 pump and cable. I was able to upload the code (reef crest) and its working great, thank you to Roberto for the tutorial.
My question is, can I use the portal or the reef angel client to change the settings on PWM? How do i go about doing that? Specifically change the maximum and minimum percentage settings on reef crest.
You could leverage the RF memory locations until we have developed memory locations specific for Jebao.
For example:
  ReefAngel.PWM.SetDaylight( ReefCrestMode(InternalMemory.RFSpeed_read(),InternalMemory.RFDuration_read(),true) );
The above function would use the RF Speed as the average speed and RF Duration as the offset.
Now you can change it in the Portal :)
Take a look at this post as well. It has logic to leverage all the "vortech" modes.
http://forum.reefangel.com/viewtopic.php?p=23072#p23072
Ciwyn
Post by Ciwyn »
Can anyone recommend a code for just running one WP40? Should I just set my relay (port5) to always on, then put one of the codes in the custom code section? I currently have the reefcrest code in there. May try the random mode code that Roberto posted though.
Right now I have port 5 set to wavemaker random and the pump stays off for longer than I care for it to.
You can actually plug it to the wall and use Port 5 for something else you may want to control.
Ciwyn
Post by Ciwyn »
Alright so I was thinking correctly. Currently I have ports available, I will stash that away for future reference though. Thanks again
All the functions are already in the libraries.
What do you have in mind?
Yes, you could put codes into a .h file and call the #include in the code.
You could have but it's no longer necessary to do that nor put the functions into your INO file. Just go ahead and use them and the new libraries will take care of it.
jjdezek
Post by jjdezek »
when i loaded this code it shut my right leds off completly my middle whites off and the rest were still on. what would cause that to happen......why is it every code i try for the jebao on here it doesnt work
ReeferBee
Post by ReeferBee »
Do you have the harness for it? What ports do you have the wp40 hooked up to?
Barry
Current tank info: 150g mixed reef
"Some of the worst mistakes of my life were hair cuts" -Jim Morrison
jjdezek
Post by jjdezek »
i just realized i used an older code set up that doesnt have my current light set up....i rewired my lights into all dimming ports and the code i used to load this one in was from when i had the lights wired into two ports. rookie mistake. not sure whats ups with the other codes i have tried though.
jjdezek
Post by jjdezek »
plugged it in my current code set and works fine.
oscarinw
Post by oscarinw »
rimai wrote:Only one ATO port can do PWM.
analogWrite(lowATOPin,ReefCrestMode(60,20,true));
I am also connecting the WP40 to the ATO PWM...
Considering this is a different wattage PWM, what are the proper values to be used for the different modes??
Re: Controlling Jebao/Tunze/Speedwave pumps
Sorry, that post is incorrect.
I'll update it, but here is how it needs to be:
analogWrite has a range of 0-255 instead of 0-100
daniella3d
Post by daniella3d »
just wondering if I only have one jebao pump connected do I need both of these lines? or just one?
