Setting up relay expansion module
lh2o
Post by lh2o »
Hi
i just got the reef angel plus controller, got it set up and i connected the Wifi but not sure how to set up 1 relay expansion module for an extra 8 plugs ?
when i read the guide it is said:
You need to place the provided jumpers to the SDA and SCL pins.
i do not know what these are ????
I think i should connect it via USB connections are rather re abut not sure where to insetting white connector in the head unit
at this point any help wpould be greatly appreciated :) :idea:
Re: Setting up relay expansion module
Don't worry about the jumpers. If your unit was bought recently, you don't need to mess with the jumpers.
They are already placed in the head unit when they are shipped.
All you need to do now is go through the wizard and generate a new code. Just make sure to select relay expansion.
lh2o
Post by lh2o »
great thanks for your help ! all is now connected
