RA Plus + Vortechs
ecam
RA Plus + Vortechs
Post by ecam »
Hello. Needed some help with a few things i want to do in my code:
1.) Display current Vortech mode and speed in my display and wifi menu
2.) Switch between Sync and Anti snych mode for 3 hrs a day and then into Nutrient mode for another 3 hrs and back to Reef crest mode
3.) Change the name of my outlets to custom names....
i.e: Port 4 = ATO Pump
and name the temp probes like
t1 = Sump
t2 = 120
t3 = 57
Thanks in advance for the help
#include <RF.h>fa
 ReefAngel.WaterChangePorts = Port1Bit | Port8Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
  ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port8Bit; // Turn off Ports 1, 6, 7 and 8 when Water Change Mode is activated
  ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit| Port5Bit;
  ReefAngel.OverheatShutoffPorts = Port2Bit |Port3Bit | Port4Bit | Port5Bit | Port7Bit; // Turn off Ports 3,
    ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port5 ) );
    ReefAngel.StandardLights( Port3,11,0,15,0 );
    ReefAngel.StandardLights( Port4,11,0,20,0 );
    ReefAngel.StandardLights( Port5,9,0,19,0 );
    ReefAngel.StandardHeater( Port7,780,800 );
    ReefAngel.Relay.DelayedOn( Port8,2 ); //Skimmer
    ReefAngel.AI.SetChannel( White, PWMParabola(11,0,17,0,0,60,0) );
    ReefAngel.AI.SetChannel( Blue, PWMParabola(9,0,20,0,15,100,0) );
    ReefAngel.AI.SetChannel( RoyalBlue, MoonPhase()/5 );
    ReefAngel.RF.SetMode( ReefCrest,85,10 );
    ReefAngel.RF.SetChannel( Radion_White, PWMParabola(9,0,20,0,0,60,0) );
    ReefAngel.RF.SetChannel( Radion_RoyalBlue, MoonPhase() );
    ReefAngel.RF.SetChannel( Radion_Red, PWMParabola(9,0,20,0,15,65,15) );
    ReefAngel.RF.SetChannel( Radion_Green, PWMParabola(9,0,20,0,15,50,15) );
    ReefAngel.RF.SetChannel( Radion_Blue, MoonPhase() );
    ReefAngel.RF.SetChannel( Radion_Intensity, PWMParabola(9,0,20,0,15,94,15) );
    if ( second()==0 ) ReefAngel.RF.RadionWrite();
    // Hardcode PH calibrations
     ReefAngel.PHMin=544; // PH7.0
     ReefAngel.PHMax=830; // PH10.0
    ReefAngel.Portal( "ecam" );
    int x,y;
    // Aqua Illumination
    x = 10;
    y = 20;
    ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x,y,"WH:" );
    ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+38,y,"BL:" );
    ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+76,y,"RB:" );
    for ( int a=0;a<3;a++ )
      ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+18,y,ReefAngel.AI.GetChannel(a) );
      x += 38;
    ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
    ReefAngel.LCD.DrawOutletBox( 12, 94, TempRelay );
Re: RA Plus + Vortechs
Where exactly you want to change names?
Sync and anti-sync is controlled by the vortech driver. Please refer to the ecotech manual on how to set it.
What are the times that you want to run NTM /Reefcrest/ any other mode?
ecam
Post by ecam »
On the reef angel display I want to name the temp probes as follows
T1= Sump
T2 = 57 SPS
T3 = 120 DT
If possible i want to build another mode like the "Water change mode" called "Sock Change" that would turn over just one of the pumps (port 6) - Cna i create this custom mode
Here is what i want to do with the vortech:
From 11:30pm to 6 am I want to run in Lagoon mode
from 6:01 to 11:am I want to go into Reefcrest mode
from 11am to 1pm I want the reef angel to switch the modes from Antisynch to Synch mode (currently im doing this manually, can the reef angel do it)
from 1:01 to 4pm i want to go into NTM and switch back to Antisynch mode
from 4:01 to 11pm I want to go back to reef crest mode
ecam
Post by ecam »
Any help?
To change the main screen, you need to create a custom main screen:
http://forum.reefangel.com/viewtopic.php?f=14&t=109
To create a new mode, you will need to create a custom menu:
http://forum.reefangel.com/viewtopic.php?f=14&t=311
For the vortech, you can use something like this:
if (hour()>=6 && hour()<11)
  ReefAngel.RF.SetMode(ReefCrest,40,10);
else if (hour()>=11 && hour()<13)
else if (hour()>=13 && hour()<16)
  ReefAngel.RF.SetMode(Smart_NTM,50,15);
else if (hour()>=16 && hour()<23)
  ReefAngel.RF.SetMode(Lagoon,40,10);
ecam
Post by ecam »
Hey Roberto. Thanks. Where in the code is it toggling between sync and anti synch mode? Can this be done? Also. Just to be sure in the code. The syntax for the vortech command is
Mode, speed, duration. Right
I.e ntm, 85, 15.
sync/anti-sync/back-of-tank has to be selected on your vortech driver. Please refer to ecotech manual.
yes, mode,speed,duration
