RA Plus + Vortechs
Posted: Sat Apr 06, 2013 12:18 pm
Hello. Needed some help with a few things i want to do in my code:
1.) Display current Vortech mode and speed in my display and wifi menu
2.) Switch between Sync and Anti snych mode for 3 hrs a day and then into Nutrient mode for another 3 hrs and back to Reef crest mode
3.) Change the name of my outlets to custom names....
i.e: Port 4 = ATO Pump
and name the temp probes like
t1 = Sump
t2 = 120
t3 = 57
Thanks in advance for the help
t1 = Sump
t2 = 120
t3 = 57
#include <RF.h>fa
ReefAngel.WaterChangePorts = Port1Bit | Port8Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port8Bit; // Turn off Ports 1, 6, 7 and 8 when Water Change Mode is activated
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit| Port5Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit |Port3Bit | Port4Bit | Port5Bit | Port7Bit; // Turn off Ports 3,
// Setup ATO Port for AI communication
ReefAngel.AI.SetPort( lowATOPin );
ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.StandardLights( Port3,11,0,15,0 );
ReefAngel.StandardLights( Port4,11,0,20,0 );
ReefAngel.StandardLights( Port5,9,0,19,0 );
ReefAngel.StandardHeater( Port7,780,800 );
ReefAngel.Relay.DelayedOn( Port8,2 ); //Skimmer
ReefAngel.AI.SetChannel( White, PWMParabola(11,0,17,0,0,60,0) );
ReefAngel.AI.SetChannel( Blue, PWMParabola(9,0,20,0,15,100,0) );
ReefAngel.AI.SetChannel( RoyalBlue, MoonPhase()/5 );
ReefAngel.RF.SetMode( ReefCrest,85,10 );
ReefAngel.RF.SetChannel( Radion_White, PWMParabola(9,0,20,0,0,60,0) );
ReefAngel.RF.SetChannel( Radion_RoyalBlue, MoonPhase() );
ReefAngel.RF.SetChannel( Radion_Red, PWMParabola(9,0,20,0,15,65,15) );
ReefAngel.RF.SetChannel( Radion_Green, PWMParabola(9,0,20,0,15,50,15) );
ReefAngel.RF.SetChannel( Radion_Blue, MoonPhase() );
ReefAngel.RF.SetChannel( Radion_Intensity, PWMParabola(9,0,20,0,15,94,15) );
if ( second()==0 ) ReefAngel.RF.RadionWrite();
// Hardcode PH calibrations
ReefAngel.PHMin=544; // PH7.0
ReefAngel.PHMax=830; // PH10.0
ReefAngel.Portal( "ecam" );
int x,y;
// Aqua Illumination
x = 10;
y = 20;
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x,y,"WH:" );
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+38,y,"BL:" );
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+76,y,"RB:" );
for ( int a=0;a<3;a++ )
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+18,y,ReefAngel.AI.GetChannel(a) );
x += 38;
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
