ATO switches malfunctioning
Graham2212
Post by Graham2212 »
Hi there
Can someone please provide some guidance on float switches? I have 2 switches - one high level and one low level. I need the ATO pump to activate when the water level reaches (activates) the low level switch. Currently, the ATO is engaging when the water drops below the high level switch (i.e. the water level has not dropped below the low level switch). This is causing the ATO pump to activate at regular intervals. Is this a coding issue, or is there something wrong with the switches? My code is as follows: (thank in advance for the help)
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit;
    InternalMemory.OverheatTemp_write( 290 );
    ReefAngel.StandardATO( Port1,600 );
    ReefAngel.WavemakerRandom1( Port5,15,60 );
    ReefAngel.WavemakerRandom2( Port6,15,60 );
    ReefAngel.Portal( "Graham2212" );
    int x,y;
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
Re: ATO switches malfunctioning
Start here:
http://forum.reefangel.com/viewtopic.php?f=7&t=240
Are they mounted like in that page?
Graham2212
Exactly like that. Concluded it to be a faulty low level switch, as this setup functions perfectly out of the water... As soon as the low level switch is submerged, only the high level switch activates/deactivates the pump based on its position (which means that the low level switch - when submerged, is always at the low level state)... This, together with my salinity probe that started to drop its reading on Thursday.... not having a great time....
PM me for RMA on the float switch.
For the salinity, please check if you are not placing the probe where you have micro bubbles.
Temperature and air bubbles are the major impact factors for bad readings.
Since you mentioned the float having a short, can you try using the salinity without the floats?
