loading initial memory settings new unit here
Posted: Wed Apr 17, 2013 4:39 pm
by ReefDevil
followed all directions get to the last step to upload and the controller blinks the red light,,, my computer screen says its done uploading but my ra screen is totally blank.... even if i unplug it and replug it in the screen is blank
any ideas or perhaps i have a bad unit?
Re: loading initial memory settings new unit here
Posted: Wed Apr 17, 2013 4:45 pm
Did it ask you to update your libraries?
You need to use the latest one, which is 1.0.3.
You can check it at Tools->Reef Angel Libraries.
Posted: Sat Apr 20, 2013 12:30 am
by ReefDevil
library update fixed the problem, thank you
this thing is awesome
Posted: Sat Apr 20, 2013 4:15 pm
by Elevatorguy1
have the same problem but i do not see a library update button. How do I update the library?
Posted: Sat Apr 20, 2013 6:10 pm
It's a daily check.
Which OS are you running?
Did you just install?
Posted: Sat Apr 20, 2013 6:49 pm
by Elevatorguy1
Mac 10.7.5, yes just installed and cancelled on the update because it looked like it hung up at 30%, thought I would be able to do a manual update.
Posted: Sat Apr 20, 2013 7:15 pm
To force update, you need to modify the Arduino preferences fine.
http://arduino.cc/en/Hacking/Preferences
use this:
update.last=1266427969865
This will trick Arduino into thinking that it's been more than a day that you checked for updates.
Or, you can just wait 24hrs.
Posted: Sat Apr 20, 2013 7:55 pm
by Elevatorguy1
Thanks Roberto
