Cant get a successful upload
mizzo
Post by mizzo »
Using the Wizard to create simple code. Keep getting an error.
just bought this unit used from someone that couldn't figure it out either.
Here are the results I guess... I'm confirmed the port, and board tried with optiboot and regular reef angel controller... Running Windows 8
Watchdog Timer
Version Menu
Standard Menu
Binary sketch size: 25,586 bytes (of a 32,256 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM4 -b115200 -D -Uflash:w:C:\Users\Mike\AppData\Local\Temp\build2962701524458462444.tmp\sketch_apr20a.cpp.hex:i
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.xxx
Using Port : \\.\COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude done. Thank you.
mizzo
Re: Cant get a successful upload
Post by mizzo »
I was told it is a new USB TTL cable, never used... The unit does seem to reboot 2x while trying to upload.
Just wanted to add that info.
Was a code ever been uploaded to the unit before?
mizzo
Post by mizzo »
I do not believe so, he just purchased it within the last couple months.
PM me if you want to send the head unit for repair.
dapg8gt
Post by dapg8gt »
This is the same issue I'm having Roberto..I posted a screenshot in another post. I get the same issue as him.. I've tried all the other things mentioned on the other threads. Com port,cable ,board,serial monitor etc...
dapg8gt
Post by dapg8gt »
This is what I get trying to copy the error code I don't think its the right thing though.. So ill include a Pic... The code below was just me trying to revert the code back to default so it was not what the wizard made it was the default. Let me know what I'm doing wrong :(
I seem to only have one com port option to choose from com 5.. Even when I switch ports it says error com port 0 not found. Shouldn't I have 3,4,5 since it said those on the driver install? If I pull the USB out the com 5 disappears so I know it's seeing it.. I have tried most every option that's on the forum except the one that works Ha Ha. And I was worried about the PH probe J/K.. :lol:
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <ReefAngel.h>
  ReefAngel.Init(); // Initialize Controller
  ReefAngel.AddStandardMenu();
  ReefAngel.AddDateTimeMenu();
  ReefAngel.FeedingModePorts = Port5Bit | Port6Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
  ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Turn off Ports 1, 5, 6, 7 and 8 when Water Change Mode is activated
  ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port7Bit; // Turn off Ports 3, 4 and 7 when overheat occurs
  ReefAngel.LightsOnPorts = Port3Bit | Port4Bit; // Turn on/off Ports 3 and 4 when Light On/Off menu option is selected
  ReefAngel.OverheatProbe = T1_PROBE; // Use Temperature probe 1 to check for overheat
  ReefAngel.Relay.On(Port8); // Always on
  ReefAngel.LCD.DrawLargeText(COLOR_STEELBLUE,COLOR_WHITE,28,121,"Reef Angel"); // Display Reef Angel banner
  ReefAngel.StandardATO(Port1); // Standard ATO
  ReefAngel.MoonLights(Port2); // Moonlights or Refugium
  ReefAngel.StandardLights(Port3,30); // Actinic Lights
  ReefAngel.StandardLights(Port4,0); // Daylight Lights
  ReefAngel.Wavemaker1(Port5); // Wavemaker 1
  ReefAngel.Wavemaker2(Port6); // Wavemaker 2
  ReefAngel.StandardHeater(Port7); // Heater
  ReefAngel.PWM.StandardDaylight(); // Dimming for Daylight Channel
  ReefAngel.PWM.StandardActinic(30); // Dimming for Actinic Channel
  ReefAngel.ShowInterface(); // Display everything on the LCD screen
