Set wave speed based on feeding mode?
Posted: Fri Apr 26, 2013 4:45 am
by Smotz
I am looking to keep my wave pump (WP-40) but set it to a steady 35 during feeding mode.
Can someone assist?
Also, how do I rename the ports in the code - instead of "Port1", etc?
    ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardHeater( Port1 );
    ReefAngel.StandardATO( Port2 );
    ReefAngel.PWM.SetDaylight( LongPulseMode(35,60,5,false));
    ReefAngel.PWM.SetActinic( LongPulseMode(40,75,4,false));
    ReefAngel.Portal( "Smotz" );
    int x,y;
    // Parameters
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
    // Main Relay Box
    // Date and Time
////  Wave Modes
byte ShortPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  byte tspeed=0;
  PulseMinSpeed=constrain(PulseMinSpeed,30,100);
  PulseMaxSpeed=constrain(PulseMaxSpeed,30,100);
  tspeed=(millis()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
  if (PulseSync)
    return tspeed;
    return (tspeed==PulseMinSpeed)?PulseMaxSpeed:PulseMinSpeed;
byte LongPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  byte tspeed=0;
  tspeed=(now()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
  if (PulseSync)
    return tspeed;
Posted: Fri Apr 26, 2013 5:17 am
Here's how to define the ports:
#define Heater Port1
And I added the if statement if your in feeding mode to set the wp40 to 35%
    If (ReefAngel.DisplayedMenu==FEEDING_MODE) {
       ReefAngel.PWM.SetDaylight(35);
       ReefAngel.PWM.SetActinic(35);
    } else {
Re: Set wave speed based on feeding mode?
Posted: Fri Apr 26, 2013 6:34 am
by Smotz
Nice!
I saw a code that turned off the skimmer if the return pump was off. I would like to do the same for my skimmer and reactor pump? Got some magic for that?
Posted: Fri Apr 26, 2013 7:17 am
This is what I use..
// Turn off Skimmer if Return pump has been shutoff.
if (bitRead(ReefAngel.Relay.RelayMaskOff,ReturnBit)==0) {
bitClear(ReefAngel.Relay.RelayMaskOff,SkimmerBit);
I have ReturnBit and SkimmerBit #defined so keep in mind the actual value is port# minus 1.
Posted: Fri Apr 26, 2013 7:35 am
by Smotz
lnevo wrote:This is what I use..
So lets say your skimmer is on port 1 and your return is on port 2 - then skimmerbit=1 and returnbit=2 ? Are they just variables to represent the port?
These are my declarations:
#define Topoff Port2
#define Reactor Port3
#define Skimmer Port4
#define Return Port5
#define Wave Port6
#define Fugelight Port8
Posted: Mon Apr 29, 2013 7:34 am
by Smotz
lnevo wrote:Here's how to define the ports:
    } else {
I am getting this error when using the above code - any thoughts?
Display_Tank_adjusted_ino.cpp: In function 'void loop()':
Display_Tank_adjusted_ino:99: error: 'If' was not declared in this scope
Display_Tank_adjusted_ino:99: error: expected `;' before '{' token
Display_Tank_adjusted_ino:102: error: 'else' without a previous 'if'
Posted: Mon Apr 29, 2013 8:20 am
The If somehow got capitalized...
As far as the SkimmerBit and the ReturnBit
No, SkimmerBit = 0 and ReturnBit = 1... Since the Port #'s are 1-8 and the bit that represents them are 0-7..
So...
For you I would use:
#define Skimmer 3
#define Return 4
Posted: Mon Apr 29, 2013 8:21 am
Also, don't you only have one WP40? If so then you don't have to run the functions for Actinic and for Daylight, you can remove the one you aren't using... unless you want them both for future :)
Posted: Mon Apr 29, 2013 8:23 am
The error code tells a lot about what it is wrong...
The error is on line 99, which is show on green above.
It's complaining about "If", which is in red above. The reason it is complaining is because everything is case sensitive, which means If is difference than if.
Try changing it to if (all lowercase) instead.
Posted: Mon Apr 29, 2013 9:25 am
by Smotz
Thank you all!
Posted: Mon Apr 29, 2013 10:17 am
by Smotz
lnevo wrote:Also, don't you only have one WP40? If so then you don't have to run the functions for Actinic and for Daylight, you can remove the one you aren't using... unless you want them both for future :)
I actually changed the code to leave 1 on 100% for testing purposes
