Poiromaniax
Posts: 180 Joined: Thu Apr 05, 2012 6:20 am
Post
by Poiromaniax » Sun Apr 28, 2013 1:53 pm
Hey guys,
I just installed the mac version of arduino (got rid of my old pc, so mac only now).
I wiped my RA clean in preperation of some new coding. When i try to write internal memory using the RA Wizard, i get the following issue:
Can someone point out to me what has gone wrong?
Posts: 12857 Joined: Fri Mar 18, 2011 6:47 pm
Post
by rimai » Sun Apr 28, 2013 7:01 pm
Thanks for reporting. It's a bug
Let me patch and get pushed shortly.
Post
by rimai » Sun Apr 28, 2013 7:19 pm
Ok, I've pushed v1.0.5
Poiromaniax
Post
by Poiromaniax » Sun Apr 28, 2013 10:58 pm
rimai wrote: Ok, I've pushed v1.0.5
Thanks Roberto. I was also having problems uploading code? It would just say "upload error"
Is that also a bug? Because the code I was uploading is the exact same code I was using previously. No changes in any way
Post
by rimai » Sun Apr 28, 2013 11:02 pm
No... no bug in there.
What was the error code in red?
Maybe a different serial port?
Poiromaniax
Post
by Poiromaniax » Mon Apr 29, 2013 1:22 am
I tried both serial ports that it gave me and both times the error message was : "Error Uploading"
Nothing else, just that
attached is my code
Current.ino
Post
by rimai » Mon Apr 29, 2013 8:08 am
I don't get any errors from the code itself, so it must be communication.
If you already check the serial port, we are down to the cable or the controller.
Does it reboot a few seconds after you hit upload?
Poiromaniax
Post
by Poiromaniax » Mon Apr 29, 2013 12:38 pm
rimai wrote: I don't get any errors from the code itself, so it must be communication.
I got it working eventually
Updated to new libraries and it seems to be ok now.
