Code to reboot wireless?
Posted: Wed May 08, 2013 10:39 am
by Smotz
Hi - my wireless drops pretty often - every few days or so I can't connect to it.
Is there a way to reboot just the wireless module on a daily basis?
I wish there was an economical way to install Ethernet for this reason.
Posted: Wed May 08, 2013 11:02 am
Are you on the latest firmware...there were some threads in the past that addressed the issue and there were fixes put in place b the manufacturer.
Re: Code to reboot wireless?
Posted: Wed May 08, 2013 11:09 am
by Smotz
lnevo wrote:Are you on the latest firmware...there were some threads in the past that addressed the issue and there were fixes put in place b the manufacturer.
Not sure. How do I get the latest ?
Posted: Wed May 08, 2013 11:12 am
by enigma32
I did a quick search through the forum and it seems as though there's an option in the wifi setup wizard.
I wouldn't know personally though, since I've never used the wizard; )
Posted: Wed May 08, 2013 11:39 am
Take a look at this thread for some discussion on it..
http://forum.reefangel.com/viewtopic.php?t=3091
I've never needed to do it myself...also there is another longer thread that had details on the issue and other workarounds like you mention which involved rebooting the wifi I believe. I'm sure Roberto will chime in with details..
Posted: Wed May 08, 2013 1:12 pm
Yeah, start with the thread above.
The new firmware 4.0 needs to be handled in a 2 step process.
Posted: Wed May 08, 2013 4:57 pm
by arch
When my WIFI drops out (which fortunately doesn't happen all that often), I remotely power the RA off and then on again.
I use a Ninja Block (see ninjablocks dot com) (connected via ethernet) wirelessly controlling a Watts Clever socket via 433MHz .
There is a Ninja Block web app, which I use via my phone to turn the socket off and then on.
Not really a cheap or automatic (though it presumably could be with appropriate code - and you can use the Ninja Block for other things). It's got me out of trouble a few times.
Posted: Wed May 08, 2013 5:14 pm
Check out reeftronics also. They can notify you if your device is offline more than an hour and gives great graphs from your RA data at the same time
Posted: Mon May 13, 2013 11:34 am
by daniella3d
Since I updated with the new firmware my wireless does not disconnect, or at least if it does disconnect it reconnect very fast because I have yet to notice an offline moment.
I just returned from a one week trip and getting info from my tank was peace of mind.
Posted: Tue May 14, 2013 4:05 am
by Smotz
daniella3d wrote:Since I updated with the new firmware my wireless does not disconnect, or at least if it does disconnect it reconnect very fast because I have yet to notice an offline moment.
Thanks I will do so.
Posted: Thu May 16, 2013 6:57 am
by Smotz
I didn't upgrade my firmware yet but I did upgrade my wireless. I went from a watchguard firewall with built in wireless to a Sonicwall with a Sonicpoint access point. Hasn't dropped since.
