RA freezes up, wont respond without reset
droopymatt
Post by droopymatt »
HI everybody! new RA unit installed this last weekend keeps freezing up. What i notice is the display does not time out and the ph and temp sensor read error, then the display goes out and wont come back up...relays stay in state that they are in when unit freezes. IM NO PROGRAMMING EXPERT AND EXPECT TO FIND OUT THAT IVE MESSED UP THE CODE, so here it is hopefully this will be easily solved, but i need to figure it out before i move my livestock over from my smaller tank :D
heres my code...PLEASE HELP
// Autogenerated file by RAGen (v1.0.4.92), (09/25/2011 15:57)
// RA_092511_1557.pde
 #define DisplayImages
 #define WavemakerSetup
 #define DateTimeSetup
 #define VersionMenu
 #define MetalHalideSetup
 #define DirectTempSensor
 #define DisplayLEDPWM
 #define StandardLightSetup
 #define WDT_FORCE
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
  ReefAngel.FeedingModePorts = B01001010;
  ReefAngel.WaterChangePorts = B01001010;
  ReefAngel.OverheatShutoffPorts = B10010101;
  ReefAngel.LightsOnPorts = B10010101;
  ReefAngel.Relay.On(Port7);
  // Specific functions
  ReefAngel.MHLights(Port1);
  ReefAngel.Wavemaker2(Port2);
  ReefAngel.MHLights(Port3);
  ReefAngel.Wavemaker1(Port4);
  ReefAngel.StandardLights(Port5);
  ReefAngel.StandardLights(Port8);
  ActinicPWMValue=PWMSlope(13,30,22,30,15,80,90,ActinicPWMValue);
  DaylightPWMValue=PWMSlope(14,30,21,0,15,69,60,DaylightPWMValue);
  CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 10
#define Max_Cloud_Duration 25
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 3
#define Start_Cloud_After NumMins(15,30)
#define End_Cloud_Before NumMins(20,30)
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen resul
  // In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the 250 minutes (or 500 minutes) can
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      else x=17;
      else x=35;
    if (lightningchance)
      int x=0;
      else x=57;
      else x=75;
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
Re: RA freezes up, wont respond without reset
I don't see anything wrong with the code.
The first thing I'd try doing is moving the wavemakers to port 5 and 6.
They have dampening components to reduce the spike generated by pumps, especially Koralias, going on and off constantly.
Or turn them into always on ports for now while troubleshooting.
droopymatt
ill give it a shot, thank you!
droopymatt
ok 24hr tested and now it works great...I am using Koralia evo pumps but i moved them to 5 and 6 and now i havent had any faults for 24hrs....Thanks Roberto, now can you point me in the right direction to get the reef client to work?
Great!!!
Please read the following thread:
http://forum.reefangel.com/viewtopic.php?f=8&t=175
The most important thing to make sure is that you have the following line on the ReefAngel_Features.h file:
#define wifi
Even if not using wifi. The Client uses the wifi code to communicate.
