Command to leave LCD and backlight on
Posted: Thu May 09, 2013 4:53 pm
by zveck
Is there a command to leave the LCD and backlight on?
Re: Command to leave LCD and backlight on
Posted: Thu May 09, 2013 5:10 pm
by Ademster
unsure. but I know you can adjust the amount of time it is on via internal memory.
Posted: Thu May 09, 2013 5:32 pm
Maybe if its set to 0...have to look at the code..
Posted: Thu May 09, 2013 5:55 pm
You can keep resetting the timer, so it will never expire.
Try placing this on loop() section:
ReefAngel.Timer[LCD_TIMER].Start();
