Command to leave LCD and backlight on
zveck
Is there a command to leave the LCD and backlight on?
Ademster
Re: Command to leave LCD and backlight on
unsure. but I know you can adjust the amount of time it is on via internal memory.
Adam
58 Gal
58 Gal
- lnevo
Maybe if its set to 0...have to look at the code..
You can keep resetting the timer, so it will never expire.
Try placing this on loop() section:
ReefAngel.Timer[LCD_TIMER].Start();
