Command to leave LCD and backlight on
zveck
Post by zveck »
Is there a command to leave the LCD and backlight on?
Ademster
Re: Command to leave LCD and backlight on
Post by Ademster »
unsure. but I know you can adjust the amount of time it is on via internal memory.
Adam
58 Gal
Maybe if its set to 0...have to look at the code..
You can keep resetting the timer, so it will never expire.
Try placing this on loop() section:
ReefAngel.Timer[LCD_TIMER].Start();
